ETAWatchlover
- 421
- 140
- 43
So I probably shouldn't reseat the glass on my noob v7.5? Or is there only the risk if you don't have mimu experience?
This looks awesome mate, really!
I think i would be an awesome part for selling, especially when the gap gets smaller too.
What Movement is in it? I forgot
RobSe1 I'll look into making a few if I get time lol. It's the SH3135
Hello Rob now is when I start my project. I will need your recommendation here Rob or any mate who can help me. I was washing my hand simple like that with my watch, some soap go over my watch so I just removed the soap with some water. After 10 minutes I see a little fog inside the watch crystal. Immediately I just removed the movement from the case and decide to start my project because anyway I need to took everything out to the case and put the watch water proof. So when I start to disarm the watch I see two different problems:
1)- The watch come without the titanium Clamping ring. How I can found that piece?
2)- I see the Crystal gasket damaged. ( that happen when I have the problem with the crystal was to high over the bezel and that make me like a maniac.
Another question is Rob what is the Hydrel Bezel Gasket?. Is that little thing in Stanley steal? like the photo show? Because take a lot removed the bezel I don't know if I damaged this thing. ( please I need some help here)
Hey Mate,
ok so I think its a good time to repair your watch when it isn't water resistant anymore.
It looks like that clamping ring is still sitting in your bezel (that stainless steel ring your pointing on your pic). Under the ring on a notch on the bezel there is that hyrtel/teflon ring. So you have to pop out the clamping ring from the bezel. You have to push it through from top to bottom! like lifting the bezel from the ring up - normally you first pop the bezel off when dissembling the watch.
Than you find that plastic hyrtel ring.
You have to replace the Crystal Gasket. You can find some on WSO Ebay![]()
Got it....!!! Rod. Some photos tomorrow. Silicon hyrtel is intact...well I think so...????
The Stainless steel part that I pointed is the clambing ring (in the diagram show a totally different one and make in titanium) I just was crazy lucking for this ring mate. The ring just was there...Lol
Now is when the situation go more complicated. Because the hyrtel can damaged very easy. Let read all this again...????
Sent from the RWI App
Now rob the most difficult point here, The silicon hyrtel I need doing attached to the pressure ring? How I can pressure the bezel without damaging the hyrtel? Oh main...….
You have to put the hyrtel back into the bezel gap! Than put the crystal back in place and press the clamping ring on. Than put the bezel with the hyrtel back on.
on some cases (if you can’t press the bezel back) you first have to stick the clamping ring in the bezel and press the complete unit on the crystal.
Rob you are the best thank you very much.... I keep you posted until I finish this project, more photos coming soon. Now I starting to bond the case with Gorilla Weld Epoxy (bond Strength 4250 PSI) the Helium valve. Let see what happen. Rob without your direction this is really hard. Thank to you one more time.
