- 7/1/24
- 44
- 35
- 18
yes should fit! thank you@drvintage will a gen caseback fit ? Anyway - Nice work![]()
Bro, I already did it yesterdaywe are waiting for a full review / presentation from @drvintage
Hopefully in a dedicated tread (this is about the SK 16200 cases)
Thanks
new aftermarket Datejust 16000 case
Hey guys, A while ago, I got into 3D modeling, just as a new creative outlet. Eventually, I bought a 3D scanner and for fun, scanned my gen DJ36. Not long after, I ended up selling the watch since I was mainly wearing larger pieces at the time. But the scan stayed with me. Back then, I owned...forum.replica-watch.info
My case is older 160xx shape. 16200 have other (thicker) side profile, anyway all parts are the same, dial, 3135, crown etc will fit. If you like the optic of my case - go for it@drvintage
Wow this case looks good. I’m planning a 162xx build, this would be the right case I guess? Also I’ve read the 16200 case is the same specs as the 14270. can you confirm?
Hey Stone P, a bit late to the party, but maybe you still remember.
I build a 16200
Hi there, a bit late but maybe you still have any knowledge you're willing to share
I built myself a 16200 using the Korean case and I used a B 25 -295-1 (2,7mm height) crystal and I sometimes have the feeling that the mag is not correct (too zoomed in maybe). I might be super wrong though since I don't have a gen real life reference. Any feedback from my attached images would be awesome on that.
I'm also using the stock bezel which I now found out is not high enough, that's maybe why the gasket is visible. Do you know which one would be the correct gasket for a 16200 then so everything looks right?
Thanks and best regards from Germany!
Hi @Stone P , you're probably busy. Are you by any chance able to help me out with this one? Best regards!
