jcagara08
- 1,156
- 101
- 63
The bosshua is the case to get which can take all gen parts, I bought his black smp case set. It does not accept some gen parts.When you purchased this second kit, do you happen to know if it was the same version as the blue SMPc case you used for this build? Would a possible tell be if the bracelet uses screws vs pins? I’m trying to determine the viability of using a gen bezel with the cases bosshua007/rafflesdials are selling as you mentioned the gen bezel didn’t work with the black SMPc case. Thanks for detailed build guide throughout the thread!
Sent from my Pixel 4a using Tapatalk
