PAM 1312 from VSF Released!
Repworld
6,393
1,599
Tricky strategy. But you have to start somewhere.
I hope they sell me without asking about the watch , I don’t order the rep don’t like first batch engraving on the side , so waiting next batch .
Genuine rubber pic
KOT1917
3,396
5,552
Russian federation
They shouldn't ask about the watch, it shouldn't concern them.
I confess, I still do not understand what kind of engraving you are talking about, but if this model fully replaces both gen 1312 and rep, 312, then I think in a year or so there is another chance that they will change / add something, and hopefully for the better.
Snil
412
375
Nordic
I’ve been to a Panerai AD in Chicago and they had no issues whatsoever to sell me straps even though I wore something completely different.
Repworld
6,393
1,599
Rubber in stock for 163 $ it’s really cheap I thought 500 $, I hope same size with rep , i will go buy it and share some pics here..
Repworld
6,393
1,599
1313 VS 1312
VS fix it plz.
Sharki06
721
249
it's just a bad example, my 1312 QC are perfect on the engraving , like your 1313 example
Reactions: KOT1917
jonnybaws
2,823
3,306
Genuine rubber pic
1312 works so much better on anything other than rubber, I put a Gen Dark Blue rubber strap on my 1312 and whilst it looks OK, it looks better on a leather strap, 1312 as long as I have it will never see rubber again!
Repworld
6,393
1,599
Fully agree with Sharki06
Here is a CG of one of the members who kindly shared photos of his pam1312 with me.
Ok but still not great as 1313 really weird from maker, it’s supposed 1312 and 1313 same CG and fully interchangeable SS .
Repworld
6,393
1,599
Gen rubber very good price , i really need to change this time I have more siami croco straps , Panerai AD told me we have more colors options.
KOT1917
3,396
5,552
Russian federation
It seems that you have been in the subject for a long time, but I'll try again: The CG is the same for all steel VSFs in the luminor 1950 case made of SS. All the differences this is the specifics of a particular instance. They are not the same and will not be 100% the same. Just select a specific qc instance that you like. I am convinced that there will be a member who will show you the CG 1312 who will have absolutely perfect engraving, but when you buy yours and get the QC, it will start all over again. This includes engravings, CPs, often shaped lever tips, and some other elements.
If you like pam1312, you should buy it and test your TD's patience with the QC. I am sure you will find yours.
This is one of the most accurate pam models from vsf to date. 1312, 1313, 1314, 1025, 1056 and others will come with the same cases.
Repworld
6,393
1,599
Old model look same engraving?? https://www.vsfactory.com/vscp/1975.html
KOT1917
3,396
5,552
Russian federation
I am convinced that not. CG, crown others. They were named VSF in this roundup, but we are used to seeing these 1312 past series under the XF brand. Yes, these factories are connected, but as we can see from the example of the current VSFs, which should have repeated the experience, sort of like their own division in the P.9010 decorate, or the 42mm submersible case form, but they don't. Apparently, at that time there were other suppliers of parts, or different specifications, and now vsf started all over again.
So no, the engravings are different here, and in general everything is a little different, but this does not negate the fact that today's vsf are the same in these details.
Repworld
6,393
1,599
Now I hope vsf update engraving same this gen pic , otherwise my rubber strap waiting 6 months.
