3K Aquanaut review
jm_brc_7057
2,663
2,120
Scandinavia
Thanks! As I suspected, small one are cheaper (but would likely not fit.
i'm thin (183cm - 80kg) but I have 17,3 wrist.
Guide you posted is what I was looking for! Thanks a lot for pointing it to me!!!
I checked how long the ends were and estimated if it would fit. Also I told the seller my wrist size and asked if it will fit (thereby have an argument in case of return).
Your welcome.
BIONONE
3,718
3,030
Bought an original strap through PP service centre for like sgd200+ only .so might be worth it to buy a gen strap instead directly
No way you got a genuine Patek Rubber Strap for around 150 US Dollars man.
Reactions: jm_brc_7057
AhHuat
31
22
My bad.just checked .sgd320 for gen rubber strap
LowKeyNovice
27
Have worn my new 3kf aquanaut for a couple days now. It is super comfortable and I love it in terms of aesthetics. My only complaint is the rotor noise. It sounds like there's a weedwacker on my wrist. It's an order of magnitude louder than any of my miota reps. Is this normal?
bombina
143
109
Thanks for the great review. Rubber B has released a strap for the Aquanaut, its $250 for a piece of vulcanized rubber, makes no sense. Anyone found a source on AliExpress, DHGate or another site for replacement straps/colors for the Aquanaut of decent quality? There are a few listing on AliExpress, but not sure how the quality is compared to, let's say the ZF or 3KF (which I hear is subpar). The 3KF strap has the pins I believe.
Reactions: Mathisbou155
WatchaholicMallorca
696
377
I’ve seen various posts on here about fitting the ZF strap and buckle to the 3KF case, my TD has told me this won’t fit, can someone confirm this is possible?
Sure I’ve seen posts on here about it
LebronXiJames
416
276
Texas 🤠
I ordered a military green rep strap from https://www.watchesparts.com/. It’s expected to arrive today but for $50+-and given it was located in the US, I decided to take a chance. I’ll post some pictures when it arrives later. I do have a ZF strap and a 3kf one. I personally haven’t tried yet to fit on the ZF strap on my 3kf aquanaut but can say the quality of the ZF strap is definitely better.
bombina
143
109
Thanks for the heads up. I checked out the website, and honestly, the pin area with the white plastic, looks exactly like the ones on AliExpress going for about 10-12$ a strap (with metal clasp, its around $20). Looking forward to the pics and your thoughts on how it compares to the 3K and ZF straps.
Reactions: stufuse
kk169
152
90
How about the clasp? Is the ZF one also noticeably better? I’m planning to get gen strap (hoping for cheaper ones with my small wrist) but not sure if I would need to “upgrade” the 3KF clasp with the ZF one. Would be most grateful if you can share some comparison photos!
jm_brc_7057
2,663
2,120
Scandinavia
The 3K strap was garbage. So I bought a gen strap. It really lifted the watch. I don’t know how the ZF compares to the 3K.
Btw I’ve sold the watch/strap already. Aquanaut isn’t my thing :)
2841
Daytona Hoarder
2,304
2,214
Read back, I did a review of this a couple of weeks ago
kk169
152
90
Thanks mate I had gone thru it and also your suggestion of using the 20mm spring bar for better fit. You mentioned the 3KF clasp is bad news, and I was wonder fi you would be kind enough to share any side by side photos of the clasps. Thank!!
LebronXiJames
416
276
Texas 🤠
I wouldn’t say noticeably better but the ZF engraving does look slightly deeper. Note the ZF clasp is the one not attached. These things seem to be scratch magnets, anyone know a good way to clean the clasp up a bit to remove some of those scratches?
2841
Daytona Hoarder
2,304
2,214
For me its not so much the visuel, but more the feel. The 3K feels like a piece of chromed plastik, where the ZF feels more like a piece of sturdy metal
bombina
143
109
So, how does the actual rubber feel of these aftermarket straps (I believe you got the green) compare to the 3K and ZF? Also do you have some pics? Thanks.
kk169
152
90
Thanks for the comparison pics! Below is a guide on polishing bracelet I came across before bit might be hard to do for the clasps with engravings...
https://blog.esslinger.com/how-to-polish-a-stainless-steel-watch-case/
Burbizia
300
150
Is it possible to buy only the ZF strap? Can you adress me to a TD selling it? Thanks in advance!
