JF 15400 v3
stufuse
3,659
2,457
Tigerdragon
7,292
1,687
did they fuck up the brusing on the bezel? its not straight like the rest, i saw the same issue on the 15202 pictures.
Reactions: vcappp
C Master
General RWI Dogsbody
Administrator
77,807
136,250
Ireland
ok newest 15400 cases seems to be bigger?
Saw that on reptime
Oh that is big. I have had a 11.2mm V2 and V2J (now down to 10.6, 10.1 excluding xtal and 10.8, 10.2 excluding xtal, respectively). The xtal height can sit proud by 0.5 - 0.6mm so your case set probably measures 10.8 ish. Still too thick though.
Reactions: vcappp
rayz20
577
152
Thickness yes but when it’s on your wrist. I thought nkbthe biggest tell is the dial. The more and more I look at all theee color dials, it’s become an instant tell for me. The tapestries are flatter and not 3d like.
There are man gen batches of the blue dial so you couldnt tell by that in Real life. On wrist impossible. But i agree the dial is more important than the thickness.
Hakai
257
98
Sure it is a jf v3 ? Does not make sense to make.the case even thicker, since it would mean to develop a new case and house more material.
It would make sense to fixe thefixed the date wheel and therefore worse the printing on the dial, so the can imprvove it again and again.
Maybe just a QC issue ? Or old parts ?
C Master
Administrator
77,807
136,250
Ireland
They do not care what cases they use. They get what ever cases their supplier gives them. If you read slaughterer62 's post, on modding the thickness, he mentions the many variants of case heights in the same versions.
Tader
254
69
Tigerdragon
7,292
1,687
Reactions: rayz20 and vcappp
rayz20
577
152
I see no difference to my V2 brushing it looks like that in the same light
https://www.instagram.com/p/BG_3P9T...tm_source=ig_share_sheet&igshid=18byy45dg8fw9
https://www.instagram.com/p/BJeMRZg...utm_source=ig_share_sheet&igshid=eczoazb4c0yp
https://www.instagram.com/p/BJeLkqs...utm_source=ig_share_sheet&igshid=axmmwhxahf4n
My v2 brushing looks like the same to me
Edit: i must say i like the black color :D normally more the blue guy but black looks really great.
The People think its Gen haha. Maybe they are? lol i cant tell with that Video's
Keylog74
3,860
1,696
Can someone update on what’s the thickness on this v3. Had a member posti a picture being 10.2mm stock from td. Wondering if improved or caliper was off :D
Reactions: corleone911
