How to Read Timegrapher Results!
johnlogan
10,197
16,420
I have had a few member reaching out in regards to the timegraph and how to read it. Repost from RWG.
Beat Number
Frequency, the vibration of a movement. The number of balance wheel swings per hour or how many times the watch ticks per hour. This is a preset, depends on the watch you order.
14,400 bph = 4 beats per second
18,000 bph = 5 beats per second
21,600 bph = 6 beats per second
28,800 bph = 8 beats per second
etc
Lift angel
The angle the balance passes through while interacting with the pallet fork. Important to be set correctly in order to calculate the Amplitude. This preset is per caliber specs.
Most modern watches have a lift angle of 50 - 52 degrees. Generally lift angles range from 44 to 58 degrees. Some other settings are present, for instance Gen co-axials angle is 30 degrees.
Results
Rate
How fast / slow the movement runs (in seconds per day)
great : +/- 5 s/d
acceptable : +/- 12 s/d
If higher / lower?
It is possible to adjust this yourself or ask your dealer to nudge it a bit.
Amplitude
The measure of the amount of rotation in the swing of the balance wheel, in either direction.
Amplitude is higher when a watch is lying flat and usually falls when the watch is in a vertical position, due to increased friction. Amplitude can also fall as the watch winds down and the mainspring delivers less power.
Amplitude is a good indicator of the movements health and if is too high or too low, or that changes too much in different positions, can indicate a problem with the movement.
great : 270-310
acceptable : 250-270
If higher / lower?
Ask for a different watch or have your watch serviced
Beat Error
The amount of time by which the duration of swing differs from one side to the other in the oscillation of a balance wheel. Generally speaking to get a beat error of zero, the roller jewel in the pallet fork must be perfectly centered.
great : 0.0-0.5 ms
acceptable : 0.6-1 ms
If higher?
Ask for a different watch or have your watch serviced.
* Please note that if you are reading your QC from the dealer, you will generally receive only the results of the watch lying flat. All the above recommended measurements are from that position. The measurements in other positions may vary
https://rwg.cc/topic/143934-how-to-read-timegrapher-results/
stufuse
3,659
2,457
Thanks for this, very helpful ???????? I had some idea but at least it’s written and can refer to it now.
Reactions: johnlogan
johnlogan
10,197
16,420
Its nice to understand how to read it. I once rejected a perfect watch due the time graph.
Reactions: stufuse
DanlMason
30/8/18
Beat Number
etc
Lift angel
Results
Rate
great : +/- 5 s/d
If higher / lower?
Amplitude
great : 270-310
If higher / lower?
Beat Error
great : 0.0-0.5 ms
If higher?
Cracking post thank you!
cannockwolf
173
162
I just checked my already accepted qc photos, luckily all very good, phew! Thanks for the post as i asked what they meant once but nobody replied
TexasRow
Hello all-
Has anyone noticed a difference in the amplitude for a hand wound movement vs an automatic?
Thanks
Specter1000
1,256
615
Cincy area
Amplitude has less to do with type of movement and more to do with how well the mainspring, gear train, and escapement are operating....all common to both automatics and manual winds.
Watch doc
I had a amplitude of 321and accuracy of-6s/d on a vsf submariner was wondering if that should be rejected
Space Man
51
36
Houston, Texas
Thank you for this.
I just received a QC for a Daytona with a 278 amplitude.
I know 300+ is a standard for a genuine Swiss Made timepiece, but I had no idea what an acceptable amplitude reading is for a Made In China replica watch.
Stevex2
5/11/21
Hi Does anyone know what these figures refer too. This image was included in my QC pictures, but I cannot make sense of them
raytron
165
37
I once heard from a Rolex watch guy that the graph should run perfectly horizontal. But he was using a witchi…perhaps they work differently.
Alan Bourdillion Traherne
755
757
Great post. Perhaps the most technically useful and informative post I've read here. My understanding of watch internals is limited but give some numbers, tell me how to read them, and a chart to make comparisons, and I'm good! Thanks!
johnlogan
10,197
16,420
It means you have a reliable movement!
unclebg
197
119
Are the following Timgrapher readings acceptable for the Clean Yacht Master?
Rate -3s/d
Amp. 317
Err 0.0ms
Lift 55.0
Isn't the Amp on the high side at 317?
