WM9 case - will it take 3135 clone?
k4jun
Ω Section Moderator
2,945
1,235
Hi,
Those WM9-s were popular long ago before I joiner a rep side.
I checked M2M and there were various offers - some WM9 projects had Eta and other had Yuki installed.
Does it mean there were two cases? Eta spec WM9 and gen spec WM9?
Or was it Eta(2836?) case where people installed Yuki?
Raddave
Administrator
66,245
17,254
Hi,
good question , i think occb2 can answer your question for sure ,
i know the Sean case will accept a gen movement (hence Yuki)
k4jun
Ω Section Moderator
2,945
1,235
Cheers RD.
So how did those evolve? Sean -> WM9 -> BK/TC?
Reactions: RolexViking
Raddave
Administrator
66,245
17,254
Cheers RD.
BK used to sell the sean cases at first , then started selling the WM9 cases , TC Cases were made from the same molds that WM9 used
Like i said OCCB2 would be the best source of info here , as im only familiar with the YM cases not the submariner cases
R2L
Put Some Respect On My Name
3,553
1,142
Another one that can add to this is rsh. He has extensive experience with all these cases and how well the movements did or did not fit.
ssouthall6
10/10/13
3,539
1,562
If you are talking the YM cases then the early WM9 cases as per the previous post were actually Sean cases, so until you have one it's difficult to know what you've got.
I've gone through several 16622 super frankens and whilst the WM9 as previously stated is unquestionably the best out of the box, the later Sean cases combined gen proportions with decent finishing.
k4jun
Ω Section Moderator
2,945
1,235
Sorry guys, I did not know there were YM-s too, I had a sub case in mind.
bill33
2,570
748
Yes the Yuki/SH 3135 fits the WM9 case.
Reactions: Aphung2
k4jun
Ω Section Moderator
2,945
1,235
Love this place. Thanks guys!
occb2
Super Moderator
14,018
4,052
The early WM9 not so much. The later ones were almost identical to the early TC case. So yes. They will fit. The 16613 WM9 took a 3135 with out issues. WM9 made an assortment of cases. They seemed to be close to rolex spec. But an example would be the YM wm9/Tc made. While a 3135 fit the back would crush the automatic winding bridge. Best way to try it is throw a cheap 3135 in it and see if it tightens in the housing and back closes.
Reactions: QueTip
k4jun
Ω Section Moderator
2,945
1,235
Thanks:) Is it safe to assume that a case w/o a rehaut is the early, and case with the rehaut is the latest WM9?
pompompurin
:3
5,130
3,229
Hong Kong
from my memory,
Wm9 v1 = 2836-2 movement? don't think it's compatible with 3135 movement
Wm9 v2 = 2678 movement / 2836-2 movement. Not compatible with 3135 movement
Wm9 v3 = 2824-2 movement. Compatible with 3135 movement
Reactions: Replisimio
k4jun
Ω Section Moderator
2,945
1,235
from my memory,
Cheers mate.
Technit1957
682
34
from my memory,
Can you add the year range that the WM9 V1,V2 &V3 versions were launched?
Sent from my SM-N986U using Tapatalk
StreetFighter
Insert Coin
4/9/20
2,880
3,432
2003 WM9 V1 ‘TW Best’ from ‘eddielee’
This is well modded. Gone is the solid midlink 93250 (not hollow, these had 116610 style solid links), I replaced it with a 93150, gone is the dial (the print was very grey out the box), the CG’s were milled and opened up, not the original insert, that's a JF insert..it still has the original non-clone 2836/2 which still works but the date not so.
It needs work. Had this 18 years..
I need a dial, hands, movement.. if anyone can help?
mech500
8,253
3,594
Now that’s a deep rehaut. maybe get a Vietnam matte patina dial and turn her into a transitional 16800?
Sent from my iPhone using RWI
