VSF Upcoming Datejust 126334 with VS3235 72hrs Power Reserve
Braemar
32
Can anyone comment on the quality of the VSF black dial vs ARF V3 black dial?
kennygconspiracy
1,814
2,208
Blue dial looks absolutely perfect. I'm dreaming.
Sent from my ONEPLUS A6003 using Tapatalk
Hazing
And So It Begins... Again
9/5/19
5,188
4,474
The watch looked good but I had to reject it because the clear sticker on the case back wasn't gen like at all.
With everything they get right, they go ahead and and try and push this garbage on us. I know Rolex makes a sticker that's intentionally difficult to make but that's no excuse.
The color is off. The size of the little green half moon is off. Terrible.
kennygconspiracy
1,814
2,208
Looking really good!
What are your thougts about that jubilee? How does it feel?
Comparing to my ARF jubilee it feels very, very soft, even without any oil or lubricant. No squeaks. Just an overall shock at the difference. I'm trying to be as objective as possible without falling prey to supporting one factory over the other, mind you.
Glidelock
55
54
Wow, seems like VSF is really killing the game!
Reactions: kennygconspiracy
Hazing
9/5/19
5,188
4,474
Hi!
Got my VSF DJ gold with jubilee
https://imgur.com/a/hhUcQZo
looks nice. I have to get used to it. I just wonder, the position on the crown. this is skewed ...
I'm not sure what you're saying. And the pics don't really show us the position of the crown so we can't (or I can't) see if it's out of position.
I'm curious though about the symbols Rolex uses on the crown.
Two dots is supposed to mean the two positions.
On sports models you have three dots indicating triplock for the 3 positions of the triplock crown.
Most Datejusts have the line under the crown. Regardless of whether it's SS or two tone. It used to be simple 3 dots with the size of the dot indicating the material for sports models. Which I know a DJ is not. But some sort of coherent system would be nice.
Subfan2020
21
17
this is what i mean! see the dots and their position. is this normal? I can loosen it up then it's down.
Jayalvin777
1,178
1,621
My vsf is ready for gold plating
I saw youe post of the vsf and arf. From the looks of it case looks more refine but pictures sometimes are tricky. What are you thoughts now that you have both cases next to each other? Also looking for the end result kf your project.
Sebapol
60
67
Vsf is a bit better than ARF in shaping to me but nothing special. Arf is closer to gen regarding case and bezel for the older model with no crown at 6 o'clock especially if you have older batch
Reactions: Tete
McDuck888
3,245
1,827
Subfan2020 (oh gosh, you were curious about the winding crown appearing a certain way while it’s screwed down - normal and all good. :) Rep, gen, and everything in between is all ‘skewed’, that’s exactly how it’ supposed to be. Don’t worry about that ;-))
Braemar
32
Does any of the TDs still have a VSF DJ41 in stock as far as anyone knows?
