- 2/5/16
- 1,676
- 1,084
- 113
Okay, I think I've found it how to deal with the issue (I certainly haven't fixed the issue)!!!!
I tried oiling as outlined and it's easy to do, even for a non tinkerer type such as myself. However it didn't make any noticeable difference and certainly didn't solve the problem.
I still couldn't get the 'yoke for sliding gear' (to use it's proper name - I think) to engage like it should. I couldn't work out what causes the yoke to move when you turn the crown clockwise. Is it just friction?
Anyway, the 'fix' is to turn the crown clockwise rapidly and firmly until it engages: a quick, firm, full spin with the fingers. I have a tendency to be very gentle when winding/time setting etc, but if you turn the crown slowly/gently, it doesn't move the yoke. A quick, firm spin however and it engages every time. You only need to spin quickly until you feel the yoke engage (so there's no danger of damaging gear teeth). Then you can just wind gently as normal.
https://vimeo.com/482790205
This totally worked for me, thanks Bubba
