muiramas
Aristocrat
18/1/17
6,055
7,975
taghe
3/12/20
received mine, it appears second hand is flat comparing with gen, or it's just me?
Ernesteka
400
117
Just received my LV yesterday and was looking forward to wear it after a little oil bath. After unwinding the crown and trying to set the date, the crown just fell off. Well thank you Mr VSF.
Also the Glidelock doesn’t move as smooth as the ones on ARF/ZZF V3. This is a bummer for me to be fair. Anyone else got this issue? I have the 1LQ Claspcode.
Gesendet von iPhone mit Tapatalk
WatchSmith.US
1,307
2,058
The crown came unscrewed from the stem. The stem needs to be removed and the crown reattached, but you can probably screw it back on although you won’t be able to attach it as it should be.
Reactions: Ernesteka
Ernesteka
400
117
Thank you sir.
Was trying to screw it back on, but then when trying to unwind the stem, i am just unscrewing the crown again, it feels like the stem is stuck. Maybe this is why I unscrewed the crown?
A watchsmith can surely help here. Just more waiting time for me it seems. Patience is key to this hobby .
taghe
3/12/20
I happened to have done the crown swap on my gen sub before, looks like you will need to remove the case back and remove stem , then attach stem to crown, maybe a bit tread lock it, I assume this should work on rep as well
taghe
3/12/20
yes mine was finger tighted...certainly VSF was rushing out a lot of these recently
Mille M
1,254
2,759
Already bathed mine without checking!
Gladly water didn't go inside.
noooobii
36
Whoops just realized this was the sub thread and not the DJ thread.
Any one tried to franken the watch with 3235 movement yet? I read in earlier pages that there was a video saying that it can take gen parts but I haven't seen any one done it yet.
WatchSmith.US
1,307
2,058
misiekped has done it. I would like more info as well.
Mille M
1,254
2,759
Please everyone check your case back. I had to tighten all 3 of my VSF's, one was little over finger tight!
Just tried my 126610LV and Yachtmaster 42.
The YM 42 was tightly screwed, but the Submariner was indeed a little bit loosen up.
This is really important.
Thanks for the info!
