sukwonee
2,027
6,465
PNW
Yes my QC LV on 7 Jan the clasp 1LQ stamp.
Don't worry 0,5 to 1 mm no one will care. Reading this thread everyday only make My OCD Increase. I will leave this thread after i get my watch.
Fellow Wiz*one!
guru
11,779
1,599
Update on the measurements, clasp code H7Z
There is a difference between clasp and buckle of .4 mm
Clasp is 19.4 mm wide
Buckle is 18.95 mm
last link 16.9 mm
For me, it is a beautiful watch but they need to improve the clasp. It feels brig and you can feel the .5 mm.
Does anybody have the latest Sub with the new clasp code 1LQ and can measure it?
YellowFin
Not pretty, hardly popular
28/1/20
2,527
2,813
Molvania
Spoons Not sure what you're trying to say. We all know the gen has underside AR. The question is: what did VSF do on their 126610 rep?
tribal
Oldtime Modder
926
1,090
Buckle is 18.95 mm
last link 16.9 mm
Thanks
Gesendet von meinem Mi MIX 2S mit Tapatalk
tribal
Oldtime Modder
926
1,090
If you read all right mine is 1LQ.
Buckle is 18,75 mm
Clasp is 18,95mm
R3w1nd
692
343
guru , I'm not sure I understand the difference between a clasp and a buckle but if it is what I think then on my 1LQ clasp is 18.9mm and buckle (the part that flips over and has a coronet) is 18.6
Reactions: Jayalvin777
tribal
Oldtime Modder
926
1,090
There are always trial and error buy measuring with a digital caliper.
But who cares we talking about small differences under 1mm.
guru
11,779
1,599
Clasp is 18,75 mm
Buckle is 18,95mm
so then 1LQ is more gen like. It is then .65 mm over the whole lenght which makes a big difference. Funny that your clasp is even smaller then the buckle. My is the opposite
Sent from iX
tribal
Oldtime Modder
926
1,090
Sent from iX
My fault it is the other way. :)
guru
11,779
1,599
Ok, you understand correctly what I meant. My buckle with the coronet is 18.95 and the clasp is 19.4. It is only 0.5 mm difference but when you are used to the normal size,
it is a big difference. Are we already talking about v1.1 or V2 lol?
What is the size of your last link?
R3w1nd
692
343
16.4
guru
11,779
1,599
Regarding the AR, my VSF has 126610 does not have AR.
I have taken some pics so that you see the difference.
First pic is 126610
next picture is VSF 116610 Hulk, same reflection and color as 126610
Next BP Sea Dweller, same reflection and size
Noob Daytona, same
next with AR, had to use a watch from my wife, this AR was done
from a Optician, mag much smaller and a light green color
last one HBB with factory lime. Blue AR
So the result shows that first batch with H7Z does not have AR
Gesendet von iPad mit Tapatalk
Reactions: Duckber
muiramas
Aristocrat
18/1/17
6,080
8,051
If Guru says there no AR, I'm inclined to believe it. My first reaction was that it didn't but I'm torn because the dial does have a great clarity.
But the Chanel above looks lie a 2x AR or good AR to the outside - Looks just like my Sinn 103.
Here's a couple of Tim Mosso Video which show the crystal really well - with plenty of glare!
