Duckber
1,585
869
I bought two of them, one for a friend and get the different batches. I noticed it, by comparing them. That's it.
Gesendet von meinem Mi MIX 2S mit Tapatalk
Makes sense, thank you for that interesting tidbit!
Are you a duffer, a dumbo or mentally sick, can't you read what he sayssssss- the difference is marginal and both are "good".
Oh, so you're rationalizing and not apologizing. Well, not a surprise.
I never said it was terrible or bad, just needs work. And they worked on it. It's not black and white, either perfect or really shitty. I just said they need work, and you chastised me for it, correct? Cmon, it's not cool having an ego when you got proven wrong.
Oh, but now it doesn't count cause it will "look like shit anyway??"....? Cmon VSF thread, this is your champion? :lmao:
Sidhu6355
324
280
Hahahaha, contradicting yourself like a pussy here- just needs work, right!! Just see your previous comments bashing out VS for having churned out a poorly made watch, you are delusional, pure delusional
Duckber
1,585
869
Okay, can you show me proof where I said they were completely garbage? I'll wait. I said time and time again it's a good rep with some flaws. Or you know, you can apologize. Cmon buddy, don't be a cornered rat. Prove it.
edit: one aspect I mentioned since the very inception has been proven to be improved upon... cmon guys, where's the vitriol? Anyone else want to backpedal like this guy? :)
Duckber
1,585
869
Guys pleaseeeee
Sorry for the posts mate. It's not often when someone talks your criticisms down to trolling and disingenuity that when they finally get cornered with proof of an actual update to one of your criticisms of the watch that you get to see them roll around and dig themselves deeper LOL
Vindication is delicious, sorry. You're cool stufuse, you took my criticisms well and understood where I was coming from, so thank you. I just had to relish the moment.
Anyone else want to apologize for calling me a troll about the end link fit and finish when tribal proved they updated it? Someone must be man enough. Muriamas? Yellowfin? Jayalvin? Or do the three of you want to backpedal and make up some workaround story about tribal's in-hand update comment too? :)
Mille M
1,254
2,759
Funny exercice!
Wich one is VSF and wich one is gen?
Mille M
1,254
2,759
They both have flaws.
Left one has sel gaps, missaligned crown on the rehaut, hour hand looks that has almost no lume on the end triangle.
Right one has different lugs (they look fatter), top right lug seems crooked, the date seems a bit to the left.
Mille M
1,254
2,759
I’m going to say that both are Gen, and the point is that if you look for flaws you’ll find them?
Exactly :D
They're both gen but they look so different because of many things like angle, light, lens and camera used...
(And, of course, even gens have flaws).
Just to show that we can't compare watches using different sources.
Here's my VSF next to them (on a lower res photo).
Can't complain about anything.
As far as I'm concerned, they all look the same, but pictures were taken under different conditions.
Enjoy your VSF's. They look amazing :)
Cheers
Pietros
MULTI ACCOUNT
14/12/18
264
254
What's your issue pal?
One of the new subtle changes on the new generation is the dial increase. It's not a big difference but it's there. VSF did not incorporate this in the rep.
That's all I said. It doesn't mean it's a bad rep. No one would ever notice or call you out on it. But it's worth mentioning.
This makes me a troll?
I think this should settle it-scroll to 04:00.
The crystal and dial size is identical for the gen 116610 and 126610 with a wider bezel.
This guy is measuring, not guessing.
So VSF nailed it on the dimensions!
https://youtu.be/jUyB2iCofOc
Sent from the RWI App
Duckber
1,585
869
Exactly :D
Cheers
The left side is easily gen. Yes focal length is a factor, true. However, show me a shot of the VSF that looks like the left hand shot, at whatever focal length you please, that shows those lugs that taper in that manner, sharp and not rounded, and I'll get one immediately. Even the right hand shot of your initial pic has sharper and non-rounded lugs than the VSF you added to the right of it.
Well he did not measure the dial, just the crystal, and is saying he's taking an educated guess based on that information. However he is unfortunately mistaken.
These guys actually measured the dial themselves (7:48 in):
https://youtu.be/DnalC9GMB5g?t=468 I appreciate you discussing it nevertheless.
watchservicesny
Vendor (Watch Repair)
1,304
788
I’m getting new 126610 and will try them on 116610 to see if they increased dial size
Until someone mesure dial on gen 126610 the issue is mute
We know from past Rolex was adapting they parts from previous caliber for new watch’s
Who knows what they did this time
Looking at gen 3235 date disc compared to 3135 disc the difference is about 1mm in date numbers but you don’t see this when you looking at gen 126610
Hard to tell what they did
Replisimio
1,131
1,122
Gods own country! Yorkshire.
The dials are the same size as both use the same crystal retainer therefore the rehaut width is the same so we can conclude the dial is also the same. Fact not fiction! It has been measured by someone who owns both. The dimensions of the bezel have been changed to increase the diameter. He didn’t measure the insert though.
