- 17/4/17
- 915
- 794
- 93
It is very nice finish on all bridges, wheels as predicted same quality as vr
Didn’t try all gen parts as don’t have any reason to do that but as you see gen balance and bridge fits with no issues
Gen auto module straight fit as well
Gen date disc don’t fit as they made date indicator seating to fit 3135 date disc
You can replace the indicator to gen but then date window in rep dial won’t line up with gen date disc- only slightly but still no go
Then you need gen dial and it may not fit into rep case (I don’t know, don’t have gen dial)
Gen hands fit as they wheels are same post diameter
Testing for power reserve now and is on 50h so far
Are the rep movement's escape wheel and pallet fork anything like the gen? Also, in gen, rolex recommends changing the barrel and the mainspring together, given how thin the barrel walls are. Is that also the case with the clone 3235?
I thought gen DW was a direct swap on the clone 3235..
I wonder if the date indicator on the 226659 is the same as 126334
Sent from my SM-G973U using Tapatalk
