rcom440
5,842
3,631
Reactions: Pizzo and Glidelock
stufuse
3,659
2,457
What are you saying curves? Are you just talking about the curve of the lugs as they get closer to the tip?
The inside edges of the lug are at an angle, if you were to measure across the lug where the SEL sits, it’ll be narrower near the case/bezel and wider at the tip. If that makes sense?
Reactions: recan1ze
WatchSmith.US
1,307
2,060
The bracelet is off of mine and I measured the inside edges of the lugs and am not seeing the taper you're referring to. Everything is 20.9mm no matter where I measure. Maybe I'm misunderstanding.
YellowFin
Not pretty, hardly popular
28/1/20
2,527
2,814
Molvania
Confirmed, checked mine as well. No angle whatsoever, the insides of the lugs are 100% parallel.
Reactions: WatchSmith.US
stufuse
3,659
2,457
On the Gen? It’s straight on vsf
stufuse
3,659
2,457
[mention]muiramas [/mention] I might be getting my wires crossed and am now seeing something that’s not there.
Ignore me for now. Late night skim reading the tread after a long day, loool
StreetFighter
Insert Coin
4/9/20
2,880
3,470
I know we haven't seen a gen comparison yet but i'd bet that the case as as close to genuine as the VSF116610 is. To get this level of precision, it's obvious that the equipment they use is very sophisticated, I'd guess they 3d scan the genuine watch case (and all parts and movement parts too!) and print it out of a funky hi-tech lathe. So it would be reasonable to say that the case of the 126610 will be bang on! If the equipment didn't do its' job 'exactly', then the parts would not fit together?
Makes sense...(?)
sicilianu
1,089
69
Hi guys can one of you upload a pic on the clasp.. from the TDs looks that the vsf clasp isn’t that great like the ARF v4 clasp.
Looks like the sel tightness is still a problem like on all other rep factories..
Skickat från min iPhone med RWI
sicilianu
1,089
69
Sent from the RWI App
stufuse
3,659
2,457
Sel tightness isn’t an issue
Wasilij-2020
19/1/21
13
The warranty card has the old Layout. I think its a vsf because of the rolex crone on the dial and on the clasp.
