VR3135 Balance Upper & Lower KIF spring
VSFObs
31/12/24
Hi,
New member (1 month or so?)
1st post! So hello everyone.
Ive serviced quite a few 2824's, NH35s etc but came across my first 3135 service recently. VR3135...
I have managed to snap both KIF springs on the upper and lower balance. Are these prone to snapping so easily? Or is it technique?
Where can I purchase replacements? (UK)
Thanks in advance!
Geonor
1,437
3,637
Norway
You need KIF Elastor 3-3 springs. Cousins should have them available. And they are very fragile, but it's mostly technique. Check out some watch making videos to see how they do it, and use magnification of some sort. Digital microscopes are getting very good and affordable. Andonstar sells them very cheap over on AliExpress.
VSFObs
31/12/24
I have just had a look, i will try the cling film trick haha..
Are the 3-3 a straight fit, i saw a post on here (the OP had 6-2) and there was a bit of modification needed to make them fit
Geonor
1,437
3,637
Norway
Pretty sure it's a straight fit. The ref 95019-4 which is the OEM spring should be the same as an elastor 3-3. You could also get a couple of gens off of eBay but it's gonna be a lot pricier.
VSFObs
31/12/24
Appreciate your help 👍 I'll get them ordered!
