Theory: Rolex Serial Number encoded in crystal Laser Etched Crown (LEC)
dogwood
2,530
5,767
Canada
I don't know if there's already a post about something like this... I honestly wouldn't know what to search for. But I was looking at gen vs. rep LECs, and I noticed that all the gen LECs aren't exactly straight:
GEN:
Whereas all of those on reps are very nicely aligned.
REP (my noob v4):
This makes me think that Rolex isn't getting the LEC dots aligned because they can't -- they have infinite money, if a factory in China can align dots on an LEC, then Rolex could if Rolex wanted to. From this we can conclude that Rolex is making the dots of their LEC not perfectly aligned because it wants to have the dots not perfectly aligned.
The second thing that I find interesting, is that if a crystal is replaced by Rolex during a service, the new crystal has an S etched into the hole in the crown:
And suspiciously, the dots on the S-version of the LEC crystal are very well aligned.
To me this feels like Rolex is encoding the serial number of the watch into the alignment pattern of the dots in the original LEC as an authenticity security feature. Doing so would be quite easy for Rolex in production, the laser etching could be one of the final steps after the case and blank crystal have been assembled, the laser etching machine simply etches a crown pattern that's distorted using a cryptographic hash of the serial number e.g. SHA256(serial_number)...
Or if they were being really sneaky they could do something much harder to reverse engineering like distort the crown using Encrypt(rolex_private_key, serial_number), because then any AD could (in theory) validate that the crystal matches the serial number on the case by reading the distortion pattern and checking to see if serial_number = Decrypt(rolex_public_key, distortion_pattern).
Reactions: AG91 and nicmend
Raddave
Administrator
67,017
18,731
The S is for SERVICE xtal
and no , the dots are burned by laser at different heights , so if you hold them at an angle they dont look straight
dogwood
2,530
5,767
Canada
Interesting... although different heights are just another way of encoding information, not unlike back in the day when we used to "burn" CDs.
Reactions: Raddave
Raddave
Administrator
67,017
18,731
im sure they would need a lot more dots to do that
Oascom
Brigged
INMATE
4,412
5,079
It's designed this way to make it harder to replicate
dogwood
2,530
5,767
Canada
I count 150 dot on the gen (138 in the crown and 12 in the hole).
Assuming each dot can encode either a 1 or a 0 (deep or shallow etching), that gives us 150 bits of "storage".
There are 36 possible characters (A-Z, 0-9) to encode. Each character would require 6-bits to encode. Technically Rolex could use 5-bit encoding if they picked 4 letters that would never appear in a serial number e.g. O-0, I-1, would be good candidates, as would Z-2 and B-8.
With 5-bit encoding we'd have enough bits to encode 30 characters in the LEC. With 6-bit encoding we'd have enough bits to encode 25 character. Rolex would probably use a few bits for parity, but that's more than enough to encode an encrypted 8-digit serial number. Even using standard 7-bit ASCII, you'd have enough room for 21 characters plus 3 parity bits.
trailboss99
Head Honcho - Cat Herder
Administrator
43,849
19,581
Um, no.
if they really wanted to do that they would use a QR code instead of the crown. Also, what would be the advantage of doing so?
Reactions: Oascom
Seadwellermike
Proud RWI Supporter
Yeah bud, your making alien space signals out of the letters in your Alphabet Soup bowl.
Chill, its layers in the crystal reacting to the laser. Nothing more. As indicated by the codes (like the S in service crystals, etc) they’ve done: if they want information there, they’ll put information there.
Raddave
Administrator
67,017
18,731
Maybe each dot is a microdot composed of 10 individual dots ......hmmmm
GrandmasterChime
Agent Provocateur
1,733
1,342
New Zealand
GEN:
REP (my noob v4):
They put the laser dots at different heights in the crystal in order to not weaken it.
dogwood
2,530
5,767
Canada
Um, no.
True… the QR code format give you a lot of stuff “for free” when it comes to encoding binary information in a 2D array.
For anyone who’s ever wondered what each part of a QR code does, here’s a great 60 second video explainer:
Reactions: madmax783
dogwood
2,530
5,767
Canada
That makes a lot of sense. Curious, is that your theory or info direct from Rolex?
dogwood
2,530
5,767
Canada
Agreed, it’s probably just my normal level of paranoia… but it raises the question of why would Rolex put an S on the crystals that get installed during a service?
Why go to the effort of having two crystal supply chains: one for originally installed crystals, and one for those installed during a service. That seems unlikely to have happened by accident, so why is Rolex making the effort to distinguish an originally installed crystal from one replaced during a service?
One explanation is that the original crystal is somehow marked with the encoded serial number of the watch… similar to how a vehicle’s VIN is marked in three places on a car: on the engine block, on the driver side door well, and under the windshield.
But obviously there could be another explanation. I’d love to know why there are S and non-S Rolex crystals. And if the LEC is simply an ornamental detail, why bother having S and non-S?
Storm.
7,978
11,493
Hackerman GIF by warrify
