The DayTona difference between CF, BTF and gen
CTime
Trusted Dealer
29/9/22
760
3,448
Guangzhou, China
Bezel
The letters are identical.
CF: whiter, a bit brighter, and clear textured which is closer to the gen
BT: bit more gray, the texture is not as good as CF
They both have a problem: chamfering the edges of the bezel more or less which is different from the gen. But it feels better this way and won’t cut yourself at least.
Dial
Lettering
Gen: Everything looks so crisp
CF: the white is closer to the gen and the lettering is as crisp as gen
BT: The color isn’t as white as CF and gen, and the lettering is a bit rough on the outlines
Subdial
Color: Clean is silver gray which is more close to gen,
BT: more silver and much more shiny comparing to gen
The circle texture on subdial
Gen & CF: 10 circles; BT: 9 circles
Rolex crown on dial
Gen: looks flat from front side, polished
CF: shaped correctly, but barely polished
BT: little difference on shaping, slightly polished
Time marker
Luminous filler: CF has correct color; BT is more gray
Shape: BT is shorter and more round
Hands
Luminous filler
CF: the edges are clean, same quality as markers
BT: it looks more gray and botchy
Shape
They both look similar to the gen and don’t have enough polishing
The center pin from BT looks not well made
Crown on 3 o’clock
Only BT has a small gap to the case
Inner bezel
CF: almost the same
BT: engraving on the inner bezel is more rough
Case shape
Look aside, gen and CF is both more round, BT is more sharp
Bracelet buckle
We could feel a little resistance from BT
Lettering
CF: more like gen
BT: a little bit different from gen and different lettering in each version
Crystal
BT: added a coating film to look more transparent
CF: sticking to the gen which don’t have this coating film
Conclusion
This thread is based on the photography provided and objectively observed. As a TD, it’s my duty and responsibility to tell my customers what they would get eventually. I should never avoid telling people any flaws, because the rep will never gonna be the same as gen. I hope everyone will be just satisfied with the final result from each factory, they had done their best. Our team will make more comparison threads and videos in the future, you will know we are really ready to serve everyone as a professional TD.
Ctime
benqben
27/8/16
Under macro lens it's easy to tell em, but hand to hand, dailywear, these are unreal. It's one of the reason they call this thing NWBIGs . It's beautiful. How far have we gotten.
guarda
You're Saying I Can Smell?
186
177
NYC
This is amazing. Thank you so much for doing this.
Reactions: CTime
JuanSB
37
27
ive heard the newest clean watch cases got really sharp edges and that btf is generally better in this regard. is it true?
JuanSB
37
27
They are the latest version my friend
No, I mean if you run your finger around the edges of both watches... Which one is more sharp (which is a bad thing for daytonas as they are supposed to have rounded edges)?
I have heard Clean is more like a Sub or GMT with sharp edges, while BTF is more rounded like GEN.
mmaggi
998
799
New York, USA
This is really all about which tolerances one is able to accept. Question: Didn't CF improve the crystal to basically match BTF's crystal?
