I am a noob and I want to ask you guys if you think that I should ask for another watch or just to get new qc pictures. I am not sure if the small dials are supposed to be more aligned?
how does it work with the qc picts?
Dial alignment is contingent on type of movement for the most part. (For example, speed masters always have wrong alignment due to using different movement than gen) Is it the correct watch and do you see any obvious problems such as missing numbers, etc? QC pics are not meant to find the rep that looks most like the gen. Read up a bit more before you buy any more watches is my suggestion.
http://forum.replica-watch.info/vb/showthread.php/little-qc-pics-138378
This is a good thread on QC pics and is in a section called "noobs start here"
yes I saw that one but you need to understand a lot more than what I do the movements so you can know the sub dials alignment is due to the movement.
Thank you I guess I will have to read a lot more before I ask anything else in this forum.
+1.I guess I will have to read a lot more before I ask anything else in this forum.
