Stem removal help Miyota quartz movement
russell.b
334
I'm trying to get the stem out of this miyota quartz movement can anyone point me in the right direction I've tried the usual and googled it only to find nothing to help me
Pics added
Thanks in advance
Sent from the RWI App
tripdog
Super Moderator
22,624
18,118
Turn the watch so that the crown is at 3 o'clock.
Following the line of the pusher stem at 4 o'clock, there is a small hole with 'push' and an arrow next to it (the hole in the grey plastic). With the crown in the first position, depress the button inside this hole (use tip of tweezers) and pull on the stem.
If that doesn't work, look between the crown and the pusher at 4 o'clock, see if there is a small lever with a hole/indent on one end, which should move in and out as you pull/push in the crown - whatever crown position moves the lever out is the one you need - push down on the hole/indent end of the lever and pull on the crown.
russell.b
334
Thanks tripdog I managed to find it !!
Pushed the crown right in NOT twist tight to the case.
Then pushed in where the arrow is marked in green and it came loose
Pics for those in case they need a reference point
Sorted thanks again
