Solution for ultrasonic cleaner
Futzorr
DO NOT TRADE WITH ME
15/8/19
516
167
Hi guys,
I just purchased an ultrasonic cleaner to clean up the movement parts in my watches. Im just wondering if any of you have any experience in using different kind of solution - both for cleaning and rinsing. What would you recommend? I would prefer something that is obtainable in the EU. I prefer high quality solution and not just water/soap.
I only need solution for watch parts - no other jewelry etc.
Kind regards
32,786
59,037
You can buy some jars that will fit inside the cleaner bowl. Put Naptha (lighter fluid) in the jars and put your watch parts in the jars. Keep a second set of jars for alcohol rinse. Use plain water in the cleaner bowl. The sound waves will penetrate the glass and work on the parts in the jars.
Don't clean the balance assy or the pallet fork this way, components can separate. Use One dip cleaner.
Reactions: mrsullivan
mrsullivan
Replicaddict
5,997
12,771
Good point, and make sure you don't use plastic cups, as the cavitation effect would be uneffective.
Futzorr
15/8/19
516
167
Good advise, ill try that. Glass bowls should do the trick im guessing?
mrsullivan
Replicaddict
5,997
12,771
Yes, plexi or plain glass are what you want.
