seagull st-1901 modification for vietnam dial, please
adi…italy
429
135
Hi guys, can I ask you where to find a guide to modify the st19 movement to accommodate a vietnam dial (position 6)? Can you recommend to me the high quality parts compatible with a cartel base case for the st19 (crown, bezel, crystal). Thank you very much. Adi
bc1221
4,079
456
https://rwg.cc/topic/107483-toads-guide-sea-gull-st19-keyless-works-and-freezing-6-o-clock-subdial/
Incase you can’t see it for whatever reason,
You remove the intermediate wheel. It’s a very large wheel between the center hour wheel and the small seconds wheel+pinion.
You take the small wheel with pinion off and use double sided tape to tape it in to place or you can use glue if you’re trying to test your luck.
