VaderTime
- 449
- 167
- 43
I never had luck buying a hyrel ring on eBay or amazon. They are too small like KJ2020 stated. My sub V9 had an issue with stuck bezel when I installed Gen xtal retaining ring and Gen bezel because the Gen xtal retaining ring is shorter than noob causing the bezel to press down too tightly against the case causing the bezel not to rotate. I assume that my V9 case has size issues causing that also.
