Hi,
I have one submariner and i want to change the ceramic bezel how do you change the bezel? What is the mm? Is it very ex?
And theres problem with my case tube. I dropped my submariner once and the crown can't screw in and i give to one watchmaker repair the crown and he replace the crown but still can't screw in. I don't know my case tube is it broken a not. How do i change the case tube if my is broken inside?
And the watchmaker change the crown and now if i set my watch time and the crown will also come out. Can i put a genuine crown on my replica submariner stem? And if can how to fix the crown when set the time and the crown won't come out?
Thanks
Thanks
