Rolex Datejust II 41mm BP V2 (unboxing + review + franken process)
pompompurin
:3
5,995
5,151
Hong Kong
Hello guys!!!!! This will be a 3-part review of the Datejust II (41mm, BP V2) and I will cover: unboxing, the review itself, and the franken process (genuine dial and genuine crown).
This is the first replica watch I have ever ordered - I have previously been ordering random parts to build frankens, but never have I ordered a complete watch from TD until now.
1. The watch ordered:
I ordered a Datejust II (41 mm) from BP factory. This is their version 2 which improves on the version 1 in terms of: different movement (2824-2 instead of 2836-2) and better crystal (AR + hidden LEC). I chose this version because it is the best Datejust II replica out there, according to pictures and opinions.
2. Unboxing
This watch was ordered from the TD and as you can see, it comes really well packaged in a cardboard box. I think that the amount of bubble wrap used for padding is enough to withstand a nuke.
(I apologize for the crap photo quality even when the photos were taken with a DSLR - the lighting in my room is very bad and I am stuck with a non-image stabalisation lens)
(Next to my franken 34mm Tudor Oyster Prince Date 74000)
Size comparison to other oyster case Rolex: 40mm, 36mm, 34mm
Although the Datejust II is 1mm bigger than the Explorer II 16570, the watch feels much bigger when worn. I can't imagine having the 42mm Explorer II 116570 on my wrist - admittedly, my small wrist isn't fun to have when it comes to wearing watches that are bigger than 40mm. Notice how the BP Datejust II SEL is quite tight and can be comparable to my gen Explorer II next to it.
In my opinion, the biggest unique selling point about the BP V2 Datejust II is the correct crown height. Having the wrong case/stem/tube height is impossible to correct by hobbyist... unless you are willing to weld and redrill. I have an OCD for crown height and this watch is perfect in that respect.
3. Review - the good stuff that is worth commending
The crystal
The crystal is excellent, it has the gen height out-of-the-box and the LEC (laser etched coronet) is really invisible - just like the gen LEC crystals where you would have to use a torch or bright light-source to find the coronet. The AR (anti-reflective) coating on the cyclops work really well - I can see the difference when comparing the Datejust II to my gen Rolex without the AR.
The crown height
Overall case shape looks spot on to gen, including the crown height (thanks to the use of the 2824-2 movement instead of the usual 2836-2).
Although the benefit of using a 2824-2 is the correct crown height for Rolex watches, the drawback of a 2824-2 movement is the date flip, which would gradually change before midnight. The 2836-2 movement on the other hand does not have slow date flips, but it does have the wrong crown height. Luckily, my BP Datejust II starts changing dates slowly at approximately 11:45pm which doesn't bother me at all - I rather have gen crown height over slower date changes (well.. owning replica watches is all about compromises - you can avoid certain flaws in order to accept other flaws).
Perhaps in the future, rep factories could consider using the ETA 2892 movement as it manages to solve common 2 problems among rep Rolex, by having: (1) instant date flips and (2) the correct crown/stem/tube height. However, 2892 movements are expensive to source and they are generally not used in mass-manufactured Rolex reps.
The rehaut engraving
To my shocking surprise, the BP rehaut engraving is perfectly aligned to my naked eyes. Each of the letters from the "ROLEX ROLEX ROLEX" pattern corresponds to the correct minute markers exactly. I was so surprised how BP has managed to do this with precision. The laser-etching on the rehaut is also excellent - the font is spot-on from the naked eye and the etching is precise.
The overall quality
The fit and finish is excellent, no wobbly SEL (solid end link) and the bracelet feels fine to me. The watch feels rigid and the quality looks identical when placed next to my gen Rolex. I still can't believe this watch cost only 5% of the gen price... imagine if more TRF people can see the beauty of this, then maybe we could get more converts to come to RWI lol.
4. Review - the bad stuff and improvements that need to be addressed
The dial's coronet
The coronet's (Rolex crown's) 5 dots are meant to look spherical and 3D, like gen. However, the BP Datejust II dial's coronet is quite flat-looking. This won't bother most people and I am just venting my OCD.
The dial's lume is TERRIBLE
I have been shining a torch at my BP Datejust II dial for the past 5 minutes in order to evaluate the rehaut engravings. Despite shining at the BP Datejust II's dial for 5 minutes straight, the lume on the dial indices and hands are not bright like C3 superluminova used on gen Rolex.
To show you a comparison, here is a pic that compares my gen Rolex dial (in the box) and the stock BP dial. I have shined both dials for 30 seconds.
The dial's words "Rolex Oyster Perpetual Datejust" is located a bit low
(but in real life, nobody will care or notice. Again, I am just venting my OCD)
The crown design is wrong
The crown has 2 dots instead of a single line (like the gen 604 crown on the Datejust II). The crown also appears to look like it has too many teeth on the outside when compared to the gen 604 crown.
Some of the dial dates are skewed to the left a bit
Looks like I either have to realign the DWO (Datewheel Overlay) or try to source a gen 3156 datewheel. But this doesn't bother me too much because hell, even my gen Rolex 1601, 17013, and 16570 has this problem for certain dates.
The crown unscrewing feels a bit rough
But it doesn't affect functionality, it just takes a little more effort to unscrew. Maybe I got a bad one? Usually rep tubes or crown get worn out and eventually they get swapped with gen crown and tube
IMPORTANT:
Despite these flaws... remember this watch only cost 5% of the grey import price for gen... and I would consider it to be nearly among the super reps of rep watches
5. Franken process with pics
I will swap the following gen parts into the watch:
1. Gen 116300 / 116334 white dial
1. Gen 603 crown (I have no idea if it would fit the stock rep tube, but other member has chimed in before that it takes some filing to get it in)
Okay it is now my bed time, thank you for reading and I will continue the franken process next time
## UPDATE 1##
I took a caliper to measure the gen crown and the rep tube... I don't think there is any way I could make the gen crown fit the rep tube so I won't be swapping the gen crown
## UPDATE 2 ##
As I have previously mentioned that the crown and tube screwing mechanism was rough, I have now applied some petroleum jelly (in the form of Vasoline) onto the tube threads and it does reduce a lot of roughness and friction surprisingly.
This tip was found here (thanks @silverclaw for the tip!)
https://forum.replica-watch.info/threads/5-easy-ways-of-improving-your-reps.182528/
eswilly
3,020
198
Florida
Wow.
You're the type of member that makes this forum great again!!
pompompurin
:3
5,995
5,151
Hong Kong
Wow.
Sharing is caring! lollll
I have read a lot of members' contribution on modding and reviews, it is the least I could do
Maron
9,469
807
Canada
Really appreciate this contribution. There's not enough shared about this model
Sent from my SM-G900W8 using Tapatalk
tchockie
651
Awesome! Love the 41mm DJII's. Rolex made the lugs pretty damn long so it wears pretty big, but to case shape and thinness make this one of the most comfortable rolex ever. I hear they're changing them to 40mm at basel this year, I wonder how the DJ line is gonna change.
I had a white V1 BP a while back, and these V2s are a really nice upgrade. I currently have a silver sticks and just bought a black on m2m today also cuz I'm a sucker for them. I also have this in gen, but it's rhodium with diamonds so it's kinda too bling and I don't wear it much, but it's my wedding watch so I'm keeping until i find my second wife lol.
Yea unfortunately it's gonna need a gen tube for the crown. The dial will also need 2 holes drilled for correct feet placement. I don't have first had experience with this build tho, so can't really offer much more info sorry.
Please keep us posted with the progress! Thanks for the great write up! Totally agree with what Maron said.
Reactions: 4nef995
eswilly
3,020
198
Florida
We tell our little kiddies the same thing!!!! Sharing is caring. Then, my son takes his bothers toy right out of his hands; looks at me and says sharing is caring!!!
SOLEX
2,932
838
Very good to know!! Glad you are installing a gen dial to really make it pop! Curious how the blue/roman dial is in rep form (especially since there is no lume to worry about!
Stuvetjee
Vendor (Strap Maker)
12,325
5,865
NL / Schweizer
Awesome! Im following this mate :)
Verzonden vanaf mijn iPhone met Tapatalk
Jenki1222
68
Awesome review! I have been reading for about 6 months now and am trying to know which TD to pull the trigger with. I understand that noob factory is updating DD II and DJ II. Have you heard this? I was always under the impression that BP offered the best quality for these Rollies but now, hearing noob carries the Best quality, I am reluctant again. Regardless, you're the man and I appreciate the contribution. I hope to make mine soon.
Sent from the RWI mobile app
Reactions: Chaparraliv
pompompurin
:3
5,995
5,151
Hong Kong
How does the BP compare to the gen? I would love to handle the gen Datejust II in person to make comparisons.
I also plan to drill 2 holes into the movement ring so that I don't have to remove the gen dial feet - I hate removing dial feet from gen dials and I try to do everything I could to avoid that. I have read a lot and this should be the way to go. But as for the gen dial and gen tube, I don't have the tube removal tools unfortunately so I will have to invest some money into that.
pompompurin
:3
5,995
5,151
Hong Kong
After reading few articles and user opinions, I get the impression that BP quality is like a hit or a miss? I am lucky that my BP is very nice when it arrived. I can't comment on noob as I have never owned a noob Rolex before, but if I recall correctly, yes noob is also working on a new Datejust II. But I am inclined to think that it won't come with a 2824-2 movement so I didn't bother waiting for it to come out first. Noob Rolex typically uses 2836-2 (incorrect crown/stem/tube height) and SA3132 (correct crown height but no spare parts available when it craps out)
Jenki1222
68
Thank you for the insight! It makes good sense. I will let you know how my experience goes!
pompompurin
:3
5,995
5,151
Hong Kong
5. The franken process (continued)
Today I have basically took the watch apart. I have never dismantled a watch with 2824-2 movement before so I had to take extra care - especially with the hour wheel cog (because it is unattached from the movement) and the washer that is placed on top of the hour wheel cog to prevent the hour wheel cog from slipping.
First step is to take the bracelet off
Then the case back was opened using a special Rolex case opener tool. The stem with the crown attached was then removed. The movement appears to be a Seagull ST2130 - the higher quality ETA 2824-2 clone from China.
I then removed the screws and movement ring clamps
With all the screws and clamps removed, the movement + dial + movement ring dropped out of the mid case
I then removed the hands, as well as a small hour wheel cog retainer that was stuck onto the hour wheel cog. I also then proceeded to remove the washer that was glued onto the BP dial as I will be transferring that onto my gen dial
This pic compares the back of the gen and BP dial, the washer that helps retain the hour wheel cog on the movement is seen on the bp dial. The movement ring used in this BP Datejust also functions as a datewheel overlay spacer
Quick dial comparison. Left is gen and right is BP rep
Here is a picture of the movement ring, the crown and stem, the washer for retaining the hour wheel cog, and the golden hour wheel cog itself
Using a marker and the existing BP dial as a template, I marked the gen dial's dial feet location onto the movement ring (at 22.5 minutes and 52.5 minutes). I think I will file grooves onto the movement ring using a file instead of drilling holes - this is because I don't have the correct drill bit that allows me to drill metal and also, I think my drill is very weak for drilling thicker metal.
Next update will be about making grooves in the movement ring. I will leave this process for tomorrow.
Autobot
172
This is great, I am enjoying watching the process unfold. Thanks for the step by step!
pompompurin
:3
5,995
5,151
Hong Kong
I love seeing a watch naked with its barebone parts disassembled. It is always interesting to see how replica watches operate beneath their 1:1 case. This is total watchpr0n :D
tchockie
651
We nitpick about all the little flaws but for me, the main difference is the weight (gen is heavier) and the feel of the bracelet. Mainly because as the wearer that's what most obvious to you. I vaseline the shit out of the bracelet and that seems to help the most. There's another thread where the bracelet edges are sanded down on a SD4K and I imagine that would help. The shine of the fluted is different. Not really enough to notice unless you have them side by side tho.
I haven't compared the bezel shape/size/angle on the v2 with the gen. The rep is out of my hands at the moment for repair, but I'll compare them when I get it back.
Great job, keep up the great work! Loving this thread
WatchFlave
191
The hack with the sd4k bracelet sounds interesting. Do you have a love?
Thanks!
Gesendet von iPhone mit Tapatalk
