rolex 16014 16030 case - reshape of a cartel 2824 case [WIP]
riderocket
303
72
Measured for you. I only have one 160xx DJ, and it uses the shoulderless spring bars.
0.85mm is the diameter at the end of the spring bar that fits perfectly to the case hole. I suppose that means somewhere in between 0.9 - 1mm hole for the case. I don't have the tools to measure the case hole itself.
Hope it helps.
maikols
375
69
Hope it helps.
Thank you sir. This kind of spring bar are in the way.
Next what about a good 6mm crown?
Are avaible a good one on ebay or where?
Let's. Check if I have to retap the crown hole
Inviato dal mio STF-L09 utilizzando Tapatalk
riderocket
303
72
The 160xx series uses the 24-600 Twinlock crown.
I'm not aware of any readily available rep of that crown, that looks close enough to the original.
If I were to spend > €250 on a case I'd buy a gen crown for around €60 (+ fitting tube). That means re-drilling and re-tapping the crown tube thread. It shouldn't be difficult for someone who is able to drill lug holes.
Again, this is only my opinion, perhaps someone else knows a good source of a rep crown.
maikols
375
69
Yes this is why i asked you for a good aftermarket crown+tube not expensive . So i can drill and tab the tube thread and install it .
This let's people to buy only the crown coz the crown tube accept original one .
where you can find an original crown for 60$ ??
regards
riderocket
303
72
Tube is easy, there are plenty of cheap aftermarket.
Crown is a bit more difficult: M2M, ebay, if you are lucky, you can find one for around €60. Used of course, in various conditions. It's a gambit as with all used gen parts...
maikols
375
69
I need to find a good not expensive rolex crown + tube .
I think most of the aftermarked crown and tube are bettar or same of the stock raffles case.
the raffles case use a smaller tube then the original one
riderocket
303
72
Rhetorical question: What's the point on making a €250 case and then using a cheap shitty looking crown?
riderocket
303
72
To be on the constructive side:
6mm crowns that I have for DJ projects:
Bottom left is Yuki, center is a cheap Raffles, top right is the gen 24-600.
For some the Yuki could be an alternative but it's not exactly cheap and it uses a tube that is not compatible with any of my other crowns.
Also the crown does not thread to any of my rep or gen cases' crown tube.
maikols
375
69
If I use a hight level and expensive crown the total cost go hight but if I use a tube that accept Gen crown and a chip one the total cost does not go hight. So anyone can change the crown with a Gen one without take care of tab the tube.
maikols
375
69
riderocket i studied today .
So we have 2 type of 6 mm crown . On is for the new model 16200 and one if for the vintage model 16030/16014 .
The difference is about the size of the crown tube . The new is 4mm and the old is 4.4 mm .
Now i'm looking for a nice crown and a tube (about 40 euro ) .
If i found a tube that has the inside size of 2.5 mm and outide of 4.4 mm i no need to retap the case hole but will accept gen crown .
Of course this make the case more expensive but can accept more gen parts.
stay connect .wip wip wip
maikols
375
69
4.1mm, 24-6000 tube
Si you change it or it is the default tube installed?
Your answer make me. Crazy.!i was waiting your answer about 4.4mm tube not 4.1.
Lol
riderocket
303
72
This is all gen from factory broached inner spline 24-6000 tube, with the corresponding 24-600 crown.
I don't understand what are you expecting. Language barrier perhaps?
maikols
375
69
Keep in mind, this is from 1979 and AFAIK the original tube of the watch. Not a whole lot of thread left. Perhaps that difference accounts for wear and tear.
In fact I may explore the possibility of getting the tube replaced.
https://www.cousinsuk.com/sku/details/generic-rolex-case-bracelet-parts-by-list/c8360
Lists crown tube thread as 4.35mm
Good luck with your search!
The 4. 4 mm is the one I think is the right and period correct.
The 4.1 mm is the ne version for 36 mm like the 16200
riderocket
303
72
You asked me to measure, I measured.
I don't feel like taking my watches apart every other night taking measurements any more.
How about sharing your own experience?
maikols
375
69
Tomorrow I measure mine.
I no want you take your apart again dont worry
Thank you for your support sir
