Review - Patek Philippe Multi-Scale Chronograph 5975P – Limited Edition 175th Annive
Godfathar
1,558
538
Europe
Godfathar mate have you asked Watchfinder about the anniversary deployant? I know he sells the normal Patek deployants separately too. My 5975R is on its way, will get it next week. Was thinking of asking him.
I have never seen the 175th anniversary edition buckle anywhere. I don't think it was made.. but please if you get to ask him if he would source a rep buckle that is for the 175th anniversary edition I would truly appreciate it. Or else, we should find someone that would make it customised.
jm_brc_7057
2,625
2,029
Scandinavia
Godfathar I will ask him. Not a bad idea.to get it custom made. Actually it is only the pin buckle part that is different. The rest of the deployant is the same.
if they have to make it custom made it's only the pin buckle's outer ring with the engravings, that has to be made. The cross logo can be used from the non anniversary version.
jm_brc_7057
2,625
2,029
Scandinavia
Only this part needs to be made. Then it can be fitted on to the normal version deployant.
jm_brc_7057
2,625
2,029
Scandinavia
Hello guys. I just want to revive this excellent thread by Godfathar with a couple of pictures and words on the 5975R, which is the rosegold version. A complete review is totally obsolete, as this in-depth review by Godfathar is awesome. And also because i mean no disrespect to the Godfathar :D
I just got it in yesterday. And i am really enjoying it. It's a really great piece. There isn't much difference from the 5975P reviewed here, other than a few key differences mentioned later.
Here are some pictures:
The watch has some cons that are the same as the 5975P out of the box:
1. The "IS" flaw on the dial is there. But it is considerably insignificant, as it is really small and not visible on the wrist. Even when holding the watch you won't notice unless you are looking for it.
2. The watch has non-functional faux pushers, that are fixed. Can't be pressed. So this is not the kind of watch to hand over to someone. I think it's not possible to change the movement with a chrono movement to get it functional, as the pushers seems fixed.
The rosegold version has some pros over the 5975P:
1. The crystal won't need AR coating. It's lightly AR coated. It doesn't blur the dial, the dial is visible through the crystal just fine.
2. The 5975P was lacking a diamond in the case at 6, which all platinum Patek's have. But the R version won't have this issue, as rosegold Patek's doesn't have a diamond there.
3. The hand is black like the gen. In the 5975P the hand was silver, whereas in the gen it's white.
I highly recommend this version or the 5975G version, as these 3 cons that are in the Platinum version, needed modification, but that isn't the case in the rosegold/whitegold reps.
I have also done a little comparison of the rosegold quality:
As you can see, the ZF 5296R is very yellowish, while the TWF 6102R on the left is very reddish. The 5975R is somewhere in between oozing quality and great finishing of the mirror polished rosegold.
The more red rosegold is, the more copper is added, therefore lowering the gold purity. In gen watches 75% gold is normal in the rosegold alloy.
Reactions: Godfathar
jm_brc_7057
2,625
2,029
Scandinavia
I asked Watchfinder, he can't get the deployant. I think a custom made one is the way to go. I don't know who to ask, though.
jm_brc_7057
2,625
2,029
Scandinavia
Godfathar Mate, sorry to disturb you. But do you know if the pushers on the 5975 can be made pushable? Because i am thinking of getting a chronograph movement installed in it, but it can only be done if the pushers can be made pushable. At the moment they are fixed on mine.
Godfathar
1,558
538
Europe
They are fixed on mine.. and tbh I don't know if the places of the pushers will align with the chrono movement you're thinking of purchasing. That's if they are also working as pushers to begin with.
jm_brc_7057
2,625
2,029
Scandinavia
Okay thanks mate. Yeah i was thinking of a ETA 7750 clone. But i don't yet know if the pushers are welded into the case or they are fixed because the movement on the inside is holding them fixed in place. Maybe i'll have to send it to a modder to check.
