Review: BK TW Submariner with WM9 LV dial and insert (Subasaurus LV)
DarthAlex
820
22
Alabama
It's Sub-a-saurus, and appropriately named given the lizard green color of the bezel insert.
The 16610 LV has really grown on me. So much so I was inclined to buy a gen, but hopefully this will do and scratch that itch saving me some, well...scratch. Thanks to BK, for the TW sub. It is AWESOME. I love the gen like construction and the fact that it can take gen parts.
The TW is the best sub out of the box I have ever seen. So many details are just so right. The construction for one is perfect. I was able to install bezel inserts by clicking them into the bezel just like you would a gen. I did in the end cheat and use some glue to keep it there but taking this watch apart is much easier than the typical noob factory offering.
The threads on the crown tube are so well machined I thought it was a gen crown tube at first. Screwing and unscrewing the crown is a breeze. It came with a gen ETA 2836-2 (Confirmed) and is currently keeping to within 1 second per day. The crystal is very nice as you can see in the photos, and the WM9 dial is outstanding. I compared it under magnification to several dials including a noob dial, the TW small marker dial, and some others I had as well. It is the best rep dial I have yet seen, and the super lume is excellent too.
The SEL's have the best fit I have seen in a rep. This bracelet has solid center links, which I may address in the future, but everything about it is fantastic. The screws are very well machined, the engraving on the clasp is first rate. The embossed crown on the clasp easily would pass for the real thing. The dive extension is the best I have seen in a replica. It tucks away tightly and has a pin with two rounded keepers that retain it inside the buckle.
Mods I performed:
I had to remove the lume from the hands and then used w@thclume to super lume the second hand, the hour hand and a fat minute hand. The lume is now equally bright but somewhat off in hue. I will have to experiment with some other hands to get it a perfect match for the WM9 lume. Another weird anomaly is that on many reps the hands will fluoresce blue under uv while the markers will glow green. Under normal light it looks white, and it will all glow the same in the dark. The WM9 pearl and dial have a slight blue glow to it under UV. My theory is that it has to do with white pigment in the lume because any white object fluoresce with the same blue color when under the UV torch. Maybe someone can shed some "light" on it and how to match it 100% (pun intended).
All the rehaut engraving on this case lines up with the minute markers! When I got the laser etched crown aligned with the six o'clock dial marker the date window was off a bit. So out came the crystal (requires removing the complete bezel assembly) and then I heated it up with a butane torch to remove the cyclops. After cleaning off the old glue I used UV adhesive to reattach it. It is now perfectly centered.
Sealing up this case was a pain in the...well you know. It turns out the crown tube leaked and every time I approached 8 ATM on my tester water would start to enter the case. This case (sorry didnt take a picture) has a recess for a base (the one that goes between the case and the tube) crown tube gasket just like the gen. This may be the source of the leak as no gasket was below the tube. I fixed it with some clear epoxy. One surprise was that the crown tube had two gaskets in it, just like the gen. Most reps have one in the tube, one outside the tube, and one in the crown. So this watch had four gaskets for the crown and tube...excellent.
While the crown tube was out I went ahead and shaved down the crown guards using a dremel and a cutting wheel (not recommended for the beginner or faint at heart), then buffed it smooth with a buffer.
I let the epoxy cure and then reassembled the case (sans movement) and retested, I let it sit overnight at 20 ATM (200 Meters) and when I came back to it in the morning it was still nice and dry. I am sure if tested this would likely easily pass 300 meters and rival a real sub...we shall see.
Serial @ 6 matches on rehaut and case, and they are also sequential on the TW!
Model number engraved @ 12 o'clock.
Engraving lines up with markers on the dial...finally this little issue has been addressed.
Embossed crown on the clasp.
I spent some time comparing the engraving and stamping to pictures of gen bracelets and honestly I just can not tell them apart.
Great screws with excellent threads. Much better than some I have seen.
Note the plunger style pin in the link next to the dive extension. This insures that the dive extension stayes tucked away. Very nice.
End link engraving.
Good side view off the SEL fit.
Love the SEL fit.
Big thanks to BK for all the help with my subasaurus project. I really appreciate the time he took to educate me on several aspects of this watch.
Here is some of the info since it will likely come up for those of you who are going to mod your TW.
Crystal Removal.
1) Remove the Bracelet.
2) Optional: Remove the movement.
3) Using a case knife pry the bezel off gently, BK likes to wrap his in a cloth to protect the case and you can pry up the bezel from the area of the crown guards, but you can also use tape to protect the lugs and pry from there too. Use caution as the bezel will come off with the tiny click spring and spring plate and you dont want to lose the click spring.
4) Next pry off crystal retaining ring, al little at a time, from one side then another. Use caution as there is a rubber o-ring that seals this to the watch case and you dont want to cut it. The crystal gasket and crystal may come off with the retainer. If it does not come off with the retainer you can simply lift on the bottom edge of the gasket to remove it and the crystal. If it comes off with the retainer then you can press down on the crystal with your fingers or thumbs (dont press upward), and it will slide down through the retainer (the only way it can exit is downward as there is an interlocking ridge on the top of the gasket that fits into a groove on the crystal).
5) Assembly is in reverse order except you will need to use your crystal press to press on the crystal retainer. Make sure it is seated all the way down so that the rubber seal at the bottom seals to the case. then you can reinstall the click spring plate and spring and snap on the bezel.
For crown tube removal on the TW BK recommends the following:
Crown tube is screwed in same as gen.
Use a screw extractor:
http://www.lowes.com/pd_232606-1083-358241_0__?productId=1065081&Ntt=screw+extractor&pl=1&currentURL=/pl__0__s%3FNtt%3Dscrew%2Bextractor
And use a T-handle:
http://homerepair.about.com/od/interiorhomerepair/ss/screw_extractor_3.htm
Insert into tube and turn counter clockwise to remove.
Here is a nice video that shows someone removing the bezel on a 16610LV:
[AME]
http://www.youtube.com/watch?v=7Ev6DJT0P4U
[/AME]
slimslim
1,206
so i ask this in a serious way. is there any point in buying a gen? wow!!!! fantastic work.
DarthAlex
820
22
Alabama
Nope, not unless you just want to own a genuine LV.
Although this has a genuine ETA 2836-2 I am going to attempt to upgrade it to an ETA 2892A2.
To quote Wikipedia:
"The 2892.A2 is regarded by many horologists as being in the same 'quality' range (accuracy and reliability) as the in-house produced Rolex movements.[8] Insofar as accuracy is concerned any movement which is expected to be COSC-certified, or is in fact COSC-certified, must meet the same standards. The ETA 2892.A2 is usually found in the more expensive and prestigious watches and brands. Owing to its relatively slim height of 3.60 mm, the 2892.A2 is a favorite of watch brands that market complicated movements such as Breitling with its trademark chronograph (stop watches). Given the slim dimensions of the 2892, it provides a good platform on which to add or build a chronograph complication. It is also used in IWC's Portofino line without complications simply for its small size."
I feel that this rep with the 2892-A2 movement will likely do it for me in both form and function. If it can keep time as accurately, and can take gen parts, and can be used to the same depth, what advantage is there in having a gen? (Well short of the obligatory Rolex membership fee of $300-$400 for service every 3-5 years, plus parts and the all important bragging rights) Plus there is a certain satisfaction in wearing something that I built and that I can service, versus something I simply purchased. If I feel the need to buy the real thing I will let you know.
:popcorn:
Bonesey
8,926
66
Stunning review, stunning pictures, awesome mods and beautiful watch. Definately something to aspire to on all fronts! +rep added mate.
JEKS
26
Could it be....
:popcorn:
I am clicking my red sparkly shoes together in anticipation. We're not in Kansas anymore...
Is the TW sub from BK ready to start rolling out? I stumbled on this hobby at what appears to the be outing of a mostly perfect sub rep and I couldn't be happier. My rep PAM232 is a beater that I get compliments on daily.
I have appealed to BK's better nature, and am willing to give up my first born for one of his WM9's superlumed black dials and hands. He hasn't acceded yet, but I plan to forward her excellent 4th grade report card as an incentive.
Anyhow, most beautiful watch! Congratulations.
DarthAlex
820
22
Alabama
:popcorn:
Let me know how that works out! I can trade him a neighbors kid for another TW. I have a two tone I'd like to build. :biglaugh:
jiddy
983
wow. that looks truly incredibly good lj
bezel insert looks damn good and overall finish is very genlike.
nice tutorial as well.
wear it well.
cheers.
j
gareth
96
25
Excellent review, that is a truly stunning LV. Let me know if you get bored of it :)
bklm1234
158
141
excellent writeup DA. Fun project isn't it? I'm glad you epoxy the tube and achieve 200 meters. Commerical time: when I mod the CGs on these babies, I always remove the tube, and then I epoxy back the tube. Theoretically I get the same waterproofing as DA does.
A lot of people wonder if the TW sub components measure to wm9 components. I think it does and exceeds in some areas, namely the bezel. Just better cut teeth and teeth length. However the retaining ring is generally thicker on the TW sub. To fit the TW sub insert on it, you just need to file the back of the TW sub insert. But to fit a wm9 or gen insert which are both less conical, you need to not only file the back of the insert but also the retaining ring's top. Get the entire thickness of the retaining ring to 2.8 to 2.82mm, then you don't have to risk filing the insert too thin. Also use a 2.5mm crystal gasket instead of the standard 2.7mm gasket. Clark has 2.5mm gasket. You will have a perfectly fitted crystal/retaining ring/insert combo.
Lastly, don't use a dremel on the CG trimming. Use a good old needle file and your hand to file them. Safe and detailed this way.
bk
DarthAlex
820
22
Alabama
bk
Loads of fun, almsot ready to do another!
You should probably listen to the man about the CG trimming! I was a jeweler in a past life so I have a lot of experience in using a rotory tool for shaping, cutting, trimming etc. One slip though and you would be crying. The file allows precise removal of material and is much safer.
If you tape off the watch and use a bench style buffer it will give the filed down edge a nice smooth radius when you are done.
Bonesey
8,926
66
Are we (as random people) able to purchase a non-modded TW sub from anywhere or do you have a monopoly on them BKLM?
