Glad you got it off, however speaking from experience and learning the hard way myself: Prying from the midsection: only do as a last resort/ backup.
Best option and the right way to do it is press out the crystal, gasket, and retaining ring together from the case... and then separate the 3 parts by pressing the crystal+gasket out from the metal retaining ring. KJ2020's tutorial for a sub is helpful in the steps here.
For others suggesting a razor blade to pry up the retaining ring from the bottom of the metal ring: In the case of the sea dweller, using a razor blade to pry the retaining ring loose/upwards is a more difficult option vs sub/GMT, due to the recessed portion on the SD43 case (that isn't present on Sub's/GMT's)
this thread has some of that discussion: https://forum.replica-watch.info/th...0-failed-crystal-swap.10992614/#post-12071466
Good luck
