Received my first REP, need help
didjital7
567
402
I scrape that stuff off with a wooden toothpick. I also use a toothpick to lift the edges of clear stickers so I can pull them off easier.
RX7GP
1,133
536
:picard:
removing stickers should be easiest thing to do.. just heat it a little if not coming off easily...
Reactions: TESLA760
Kielxx
1,797
2,938
how much problems will be with unscrewing the crown if removing plastic cause so much trouble;)
p0pperini
patr0n h0arder
8,987
30,149
We all have to start somewhere. And those little blue stickers are a bugger to get off. So I don't blame the OP for coming here for advice.
Oh god, I'm turning into P..DR..D
But anyway, when I got my first Sub rep, I broke fingernails in my fruitless efforts and then messaged the seller to complain that the crown was impossible to pull out. He politely explained the concept of the screw-down crown to me.
P..DR..D
KING OF LINKS
20,820
19,389
Éire
I remember seeing someone recommend tooth pics (like didjital7) and worked a charm for me too. They can be annoying, but rather them than scratches.
:lamo2:
A hearty chuckle to start the day, thank you :thumbsup:
toogoodtobetrue
Looking Around
13/6/22
Thank you so much everyone!!! These are all helpful tips. I didn't know what it was, so a bit afraid to try anything because it could cause a damage. Thank you, thank you!
Feefo
Your cleverness is mistaken for your cleverness
Top Poster Of Month
8/5/22
12,591
28,620
Not that stupid a question after all, was it? Thanks for the different solutions, had the problem myself very recently. And thanks to the help of experienced members, exactly what daytona4me meant by his post I just read minutes ago ("where you once a noob?"). I love this community.
leo6929
1,676
1,084
As simple as it sounds, I once had a very tough one not coming off, it just wouldn't budge. I decided to then go ape on it with a toothpick. It will take some time, but that will not scratch the metal.
Yogibear
1,409
614
You must have had a really tough one. Usually the crown sticker is already peeling off. The bracelet is annoying. Especially when the stickers are really stuck into the clasp.
Reactions: leo6929
Yogibear
1,409
614
I had one on my hulk that wouldn't come off. I gave up and accepted it as part of the watch.
Reactions: Feefo and leo6929
Raddave
Administrator
66,243
17,254
hmmm id try a dremel with a cloth polishing wheel
Reactions: RX7GP
mclarendude
𝙟𝙚𝙩𝙨𝙥𝙚𝙚𝙙
26,709
29,459
ATL
Worse comes to worse, q-tip with acetone. That what I do!
JTL12
135
46
A quick dip of a Q-tip in acetone will take these right off and not damage the crown at all.
