R2D4's 45.5 Planet Ocean Part Number Reference Guide
R2D4
Admin
14,905
42
Here you go fellow modders! This list should help you with shopping at your local Authorized Dealer.
If you see a mistake send a PM and I shall fix thee! If you feel this worthy then Sticky it!
Originally Posted by Inushuk
Hi
aHere are all the exact ref at cousinuk for the gen parts for PO 45,5 mm
X20079 Omega 062SB3063- Sapphire Glass
X20376 Omega OME-2500-Dial#3 (064WK3170001) - Black Dial
X21168 Omega HAN-4221 (065WZ4312) - Steel With Luminous Infill Hour & Minute Hand
X21169 Omega HAN-4222 (066WZ4313) - Steel With Red Tip and Luminous Infill Centre Seconds Hand
X21285 Omega 082SU1703 - Planet Ocean Black Bezel Insert
42184ST Omega 069ST42184 - Crown 9 x Ø6.10, Depth 4.50 Stainless Steel Waterproof
X12870 Omega 090ST1232-Case Tube
X22746 Glass Gasket (X22746) x 1
ETA280225571WB3 ETA date wheel - white on black 3h - 2557/1 for 2802 -
cheers
J.
Reactions: JLFast
lnoblesus
10/5/06
49
Re: R2D4's 45.5 Planet Ocean Part Number Reference Sheet
This is just what I needed. Great work.
R2D4
Admin
14,905
42
spookycord said:
Someone pin this jewel
Thanks spooky, I am sure it will save someone lots of time.
Thank you Sir! If you do use it make sure you have your AD give you the description of the part. If you go the bezel route, I believe it does come with the retainer. I need to fix that.
Enjoy!
R2
R2D4
Admin
14,905
42
Update #2
Update #2
Added Retainer to Bezel Assembly.
42.5 Version coming Soon to a Board near you!
daytona4me
sorry who are
Administrator
13,626
10,157
Thanks R2D4.
I just stickied this. Great Reference Guide!
buffalox
Horology Curious
22/1/09
Just adding to the knowledge (mainly for the hands and dial)...
Omega 064WK3170001 - Black Dial
Omega 065WZ4312 - Steel With Luminous Infill Hour & Minute Hand
Omega 066WZ4313 - Steel With Red Tip and Luminous Infill Centre Seconds Hand
Omega 082SU1703 - Planet Ocean Stainless Steel Bezel With Black Insert
Omega 085ST0090 - Bezel Wire Click Spring
Omega 129ST0515 - Bezel Flat Click Spring
Omega 42184ST - Crown 9 x Ø6.10, Depth 4.50 Stainless Steel Waterproof
Omega 062SB3063 - Sapphire Glass
(Source: Cousins UK site)
SpootyPuff
1,265
62
Found the gen case back on Ofrei's:
[FONT=Arial,Helvetica,Univers,Zurich BT]OME-112ST1703
Any idea if this will fit a rep? or will we have the same issues as the bezel?
[/FONT]
I supposed I should've started a new thread eh?
miguel365
265
Gen case back
Does original case back Big size fit to UPO 45mm ?? I see in guide it have an *...
Thanks if someone know this.
:stir:
Inushuk
Put Some Respect On My Name
19/10/10
5,500
ETA datewheel - white on black 3o'clock - 2557/1 for 2892 compatible with 2824-2 - on sales @ couzinsuk.com : £18,35
I did check the compatibility on www.eta.ch
Thanks to Pugwash from RWI for the image :
ETA2824 datewheel (that is into "our UPO") compare to a gen ETA2892 datewheel (on the right). Look at the difference
Inushuk
19/10/10
5,500
Here is the real difference ... The ETA original Datwheel 2557/1 for 2892 compatible with 2824-2 (ordered at couzin for my Franken) and the UPO latest model (no happyfeet just received) before sending for transformation as Franken
Q5?
15,273
I will do this mod to my FrUPO.
tokeyx
456
Can anyone recommend someone to do the complete FrUPO rebuild? I'm going to order the dials, hands, datewheel, crown, bezel insert and am wondering who has experience doing the rebuild?
Inushuk
19/10/10
5,500
If you are in Europe you can use Uwe from Finedd he did the job for my 2 Franken UPO.
Just check here about my franken ...and see what Uwe did !
you can find all details about Uwe on the forum. He also have a specific topic.
Mr. Pap
7,350
171
I cant find the date wheel at ofrei... Does any one know the part number?
Inushuk
19/10/10
5,500
I do not think Offrei has any ETA parts ...so you need to find somebody who carries Eta products as this datewheel is an Eta part
olworthers
2,171
32
Great thread!
I'm looking to Franken my UPO with the orange numbers on the dial and orange bezel (Pumkpin!), like this:
According to the CousinsUK this is the correct dial:
This looks correct to me, the gap between the date window and the 3 o'clock marker being correct for the 45mm model.
On the Ofrei website they show this dial:
This looks like the date window is closer to the 3 o'clock marker, like the 42mm model. This actually looks more like the dial in my first picture, which is a 45mm taken from Omega's website.
They are both listed as being for the same case number (168.1652) - but the Ofrei option is €65 cheaper. This doesn't include postage (I'm in the UK so Cousins would be cheaper postage, but it would still be a considerable difference). Anyone got any experience with these dials....?
Thanks in advance
OW
Omega88
1,062
Hi guys,
from ofrei , is 062SB3036 crystal comfirm to have double AR or just normal clear crystal.
Cos 062SA3007 says to be anti reflective sapphire crystal. Why they never mention 062SB3036 as anti reflective? Is that mean its not coated with double AR?
Thanks for any reply..
