Quick Review of Clean Factory V2 Insert for Rolex 116610 LN vs. V1
jtimewatch
Trusted Dealer
Trusted Dealer
12/3/19
402
1,203
Guangzhou, China
Hi guys,
It's Li from Jtime again, and sorry to bother you guys some time to have another reading.
About 2 months ago, I have posted a thread about the Clean Factory bezel and insert for Rolex sub 116610 LN, and here is the link: https://forum.replica-watch.info/for...f-noob-and-vrf
Also some days ago, I have posted another thread about the new ZZF sub compares with GEN and some other sub reps, here is the link: https://forum.replica-watch.info/for...nd-nail-part-i
As I have told everyone that ZZF sub is using CF V2 insert, so many members may already have seen the insert, and some members are interested in how the V2 looks comparing with V1.
I have got a few pcs of V2 insert about 3 days ago, so today I am here to share a quick comparison about the CF V1 and V2, it may help people here to see it more clearly.
So let's get down to the pictures.
Front View of 2 Inserts
Well, we may not tell some obvious differences between the V1 and V2 if we just have a quick glance over them.
But if we look a little bit more carefully, then we will find the some differences:
1. The distance between markers and the insert inner edge on V2 is a little bigger than V1, I think some member mentioned it in the V1 review.
2. The engraving color seems a little bit different as well.
OK, let's go closer to those markers details.
Numeral Markers Close View
Stick Markers Close View
From all these above, we can that:
1. Platinum plating on V2 is more exquisite than V1
2. Depth of the engraving is a little bit deeper than V1
3. Finishing of the engraving edge is better than V1 with a better 3D effect
4. Color of the plating is a little bit brighter than V1
5. Distance between markers and the insert inner edge is a little bit wider than V1
Pearl Triangle Close View
Pearl is same as the V1.
But sadly, the upper edge of the triangle should be closer to the outer edge of the insert because gen insert has a little bit smaller distance here, as well as the edge line should be curved a little bit in order to closer to the gen.
Overall, I think the Clean Factory V2 insert could be one of the best rep inserts at the moment.
But like what I always said in other threads, this is only my opinion, everyone will be always be welcomed to share different thoughts and opinions here.
OK, this will be the end of this quick review now.
See you guys around and cheers!
All the best
Li
Jtime Watch
Jpme
87
77
Seattle, Wa USA
Good improvements. The pearl is still too white. If they could just get the color to have that tinge of grey/creme of the gen, it would be great.
Any changes to the bezel? Once they space out the teeth it would be super close to gen.
Jbrahm
69
25
I bought the CF bezel from Puretime when it just came out. Do you happen to know if they sell V2 or V1? Mine looks like V2 in how clean it looks but the differences seem non-existent...
rolexlover101
145
19
Awesome.
is the insert a direct fit to the Noob v9 bezel without buying the CF bezel?
d3s19n
646
518
jtimewatch the ZZF 116610ln you used in the review seems to have the V1 insert. Will the real ZZF once they are released have the V2?
rolexlover101
145
19
That's awesome. Can you PM me the price of the v2 insert and how to purchase one. Many thanks jtimewatch
d3s19n
646
518
No mate , ZZF is using the V2 already. You can have a look at the V1 review then you will know.
Yes I see it now. ZZF uses V2 which looks excellent! Thank you
I’m curious to know what do you do with the V1 stock as they are very inferior and now nobody will want one when they have the option for V2?
k4jun
Ω Section Moderator
2,944
1,236
Well done. You are very close in making a rep insert which makes gen not worth buying. Price is the same I assume(?).
Jbrahm
69
25
Can you please answer my question? If I bought the CF bezel from Puretime, that is only V1?
nonox
261
74
Oh my....mate.
I kept my mouth shut not to answer your question because I just don’t want to break you heart. Lol.
But if you insist, ok let’s go , it is V1.
Sorry.
do you have any idea of ​​the release date of v2 ?
Thanks
xartan
2,692
1,056
V1 is not bad IMO. I have it still waiting for the watch to put it on to arrive haha.
Reactions: d3s19n
