Problem DISCOLORED gold after 5 month
ym6666
I have a major issue here.And I honestly don't know what to do.Any suggestions?
I bought a Nautilus 5711 RG PPF 1:1 Best Edition Gray Dial Diamonds Bezel on SS Bracelet 324CS. But after wearing it for 4 months the rear got discolored so fast. It's really unfair after paying 550$
What should I do? The watch was bought from Jtime
asusundevils1971
Top Poster Of Month
23/2/23
25,119
44,525
In Your Head
There is nothing you can do other then spending some money to get the watch re-plated. When you buy a gold plated rep watch there isn't much actual plating on them and the gold wears out quickly. It looks like you have worn the watch a lot in the five months you have owned it.
There is some maintenance that needs to be done when wearing a rep gold watch After the watch has been worn you need to clean it because the oils in your skin will discolor and fade the plating.
Shame you were not a member here before ordering because there a few threads that talk about the plating on full and two tone watches fading. So you have two options 1. wear it as it is or 2. spend a few hundred dollars to re-plate it.
shinynewbling25
aprilia
29/1/15
1,918
3,685
Where your daughter is
I like your rep choice and give you props for wearing like it should be worn. It's unfortunate about the color but at least it seems only on the back and probably isn't all that noticeable on the wrist. Not sure what I'd do. Spend hundreds to get it replated or just get another to have a pristine one and wear the piss out of the already worn one. I would probably lean towards the 2nd option. Or just deal with it and continue wearing and enjoying.
ym6666
Impolite and sounds like an ahole.
Bear in mind that since you were not a member when you bought your rep, even if this is a problem of the TD and/or the factory, you are not covered and we won't give you any help
Listen. Relax and go eat some mixed fried rice .
ym6666
Bear in mind that since you were not a member when you bought your rep, even if this is a problem of the TD and/or the factory, you are not covered and we won't give you any help.
Don't need ur help. It's seems like ur some kid most probably the son of the vendor. Don't worry won't ask for a refund .
Maximillian
3,216
6,297
Böhmerwald
How low a person could go by accusing others who urge him to follow the rules the son of a vendor? If you don't need help, why are you opening a thread to whine? to show off your discolored rep to us? We have too much visiting us these days, we don't need clowns, go beg for help in Reddit.
25,883
Another racist complaining new member expecting gen level qualities for rep prices and then blaming TDs.
Lower your expectations. Ever heard of basic chemistry? You think you're getting real gold for $550? You should have done research and gotten it plated for $200
Reminder a real RG 5711 costs 185k, you can go buy that.
and let me tell you? Would it shock you that even real gold discolors after time?
Go back to Reddit please.
