"pip" at top of outside ring, replacement piece
SketchyNoob
Horology Curious
20/10/22
This may not be the appropriate forum.
I have a rep Omega that had an oversized "pip?" in the inverted triangle marker at the top. In fact, it was marked down because of this and I have absolutely no issues with the watch. Well, that "pip" fell off (my wrists smack into things all the time, been a lifelong issue with watches:rolleyes:) revealing the smaller "cup" into which it was fastened/glued. The empty "cup" doesn't look bad and I could leave as-is, reattach the original over-sized "pip" or maybe find a replacement "pip".
Is there a place you can buy those "pips" (with lume or not, don't care there)? I will be able to measure it down to the 1000ths of an inch with some small calipers to where I could set a replacement piece down into the "cup".
Any ideas or eyerolls are appreciated.
fnfalguy
79
209
33
Search alix. They are dirt cheap. Example below
Just found this amazing item on AliExpress. Check it out!
$4.90 | White Beads Blue Green Luminous Pip Watch Bezel Insert 12 O’Clock Lume Pearl Dot Mod Parts Replacement Spare Accessories
SketchyNoob
Horology Curious
20/10/22
Thank you folks. I had tried some generalized internet searches, but wasn't using the right strings. That link is great.
