Pearl Removal
Raddave
Administrator
67,017
18,790
Does anyone know how to remove the pearl from the newer ceramic inserts?
Ive done it on the older ones with the small posts but these newer ones look like the insert will be more fragile due to the larger holes for the thicker post.
Looking for the quickest, safest, easiest way.
[MENTION=83013]smoke[/MENTION] bro i hope you see this your inbox is full !
dbane883
1,251
hold a soldering iron to it for a few seconds. it will pop right off.. just be careful not do do it over shag carpet. those little critters are hard to find if you drop it!
Smoke
14,093
2,220
I use a hair dryer but Mr bane knows his stuff try this
Leronira
137
Tried using soldering iron, doesnt work :O
touch the iron on the ceramic around the pearl? Or the iron on the pearl itself?
Raddave
Administrator
67,017
18,790
Touch the pearl
Leronira
137
still not working :/ im touching everywhere on the pearl
*edit: how long do I have to touch before I get any reaction from the pearl?*
Nvm, I manage to get the pearl out with the soldering iron after touching it for 15 mins. it just drop off...
Smoke
14,093
2,220
Just remove the entire insert using a hair dryer or soldering iron .when it's hot twist and try to move the insert.when it's loose try to get under it with a pin or a blade.pull out insert and push out pearl from the back.if u can't do that just heat the pearl and pull it up with a blade or finger nail.I normally pull the pearl using a rasor blade without removing the insert
R2D4
Admin
14,908
56
Am I being punked? Lol
Leronira
137
Smoke I manage to take it out already :)
R2D4: lol thats what I did :D
R2D4
Admin
14,908
56
That's what she said! Lol glad you got it sorted.
Raddave
Administrator
67,017
18,790
Sounds really kinky to me. [emoji6]
Thats what i thought when i first posted it, but then i thought "nah, these are all adults here......"
R2D4
Admin
14,908
56
I have my weak moments Dave and I don't often loosen the neck tie. ;)
Raddave
Administrator
67,017
18,790
Its all cool bro ! We love it when you "let your hair down"
Raddave
Administrator
67,017
18,790
Lero, did you get your new pearl installed?
