Panerai Style Blacpain FF
elchino
502
619
Looks good! So did the Pam 24mm fit well on your FF? Because I thought that the lugs of the FF were 23mm.
Thehitman
7,947
326
They are 23mm but I have had about 3 24mm straps with no problem on it!
Thehitman
7,947
326
The ff is nice!! The Pam straps fit like a glove!
Lagunax
2,845
1,857
Yes the 24mm leather should squeeze in just fine but not the metal tubes.
24mm dive straps squeeze in fine too, such as the 24mm Isofrane or 24mm Bonetto Cinturini 321.
elchino
502
619
Great to know that i have many options to fit my future new FF!
Lagunax
2,845
1,857
Don't forget to buy 2x size T4 Torx screws so you can change the strap if you get the Noob version.
D
d4m.test
Guest
LOOKIN' GOOD. Looks complete and gen-like with that strap. Great move!
dave
Thehitman
7,947
326
Well then i'll get a set with different sizes :) thanks!
That's what I did from eBay... I found I don't need two of the same size...? If you put pressure on the strap near the lug bars it doesn't require 2 torx to get them off. But watch those little screws I need to get spares as they like to get lost.
Now who knows of s place I can get extra bars and screws? I'm bound to lose them...
elchino
502
619
Can you get a couple from Panatime and make fit? I know they're not the same shape as torx on FF but at least they could fit.
darby g
885
Looks damn good with that strap on there, I've got some ideas for my future BPFF now
elchino
502
619
What would they screw in to? The BFF has microscopic torx screws on both ends of the bar I believe?
Oh i'm not sure of that! I dont think these Panatime's screws are microscopic. The best thing could be source the torx screws with a TD but it's gonna be difficult 'cause Noob factory does not sell parts, but we can make the request with some of the TD and probably we'll be lucky.
