PAM617 movement swap advice
superspark69
3,183
2,249
Sheffield, UK
Hi does anyone know if its possible to swap the p3000 clone movement from the 617 with a A6497?, I ve got a f$$ked up movement thats dead and buried so was just wondering if this would work to swap it?.
ceesq
725
34
I dont think it will fit the P3000 have a different diameter and thickness(afaik), maybe with a different movement ring
superspark69
3,183
2,249
Sheffield, UK
I don't think the handset will fit the 6497 as the CP seems wider on the 6497 but maybe I can broach the hands to fit? or can you get a smaller cp on a 6497?
capice
2,713
558
The data of the ETA 6497 are:
Data
16.5''', Dm= 36.6mm, Do= 37.2mm
H= 4.2mm
F= 0.5mm
T= 1.85mm
15/17 jewels
f = 18000 A/h
power reserve 50h
Balance staff U3461
Stem W1418
Mainspring / battery
Zf3016, 1.50 x 15.0 x 0.18 x 450mm
Hands
2.00 x 1.15 / 0.27mm
Reactions: iPisi70
ceesq
725
34
Drr80
515
102
El paso, TX
Doesnt the 9000 take 6947 parts? Its just a glorified 6497 with 2 barrels
Sent from my SM-N960U using Tapatalk
mysterio
9,793
867
The P.9000 is automatic, the 6497 is a manual wind. Maybe you got your reference numbers wrong? If you're referring to the P.3000 (which is used on the PAM617), there is a tear down of the P.3000 somewhere but I am not sure if there are any common parts with the 6497.
superspark69
3,183
2,249
Sheffield, UK
So the new movement arrived today, this is what I have found.....
1. the movement does fit into the case.
2. The canon pinion and hour wheel is thinner in the rep movement so the hands will need to be broached to fit. (Hour wheel tube in rep 1.3mm, 6497 is 1.8mm)
3. The dial feet do not fit into the new movement so these will need removing and dial affixed with tape/glue dot.
I did look to see if the cannon pinion/hour wheel would fit the 6497 but it won't.
now to buy some broaching files
superspark69
3,183
2,249
Sheffield, UK
progress, just need to fit the hands now
Reactions: ceesq
klockjohan
El Patron
5/12/15
361
121
Beautiful work mate.
I have almost ordered a new movement many times but never had the guts.
can I ask where you sourced it from?
klockjohan
El Patron
5/12/15
361
121
In the old days getatwatch had decent hands for 6497/98 if you fail.
I don't know how they fare today though.
