insider pics, should be releasing soon
It's almost there now..
https://puretime.io/lrs2018062701.html
Price and details are missing. And 46 instead 47mm, i guess they will be adding + 1 mm after the release.
Is anyone aware if the blue face will be released with the V2 updates as well?
There is no announcement, and I don't expect one to be made. Simply because we are talking about two totally different movements. The PAM382 is using a P.9000 with the balance wheel @7. The PAM671 is using a P.9010 with the balance wheel @11. The P.9000 movement has a true superclone, a new movement which looks and functions like the gen P.9000. The P.9010 does not, it is merely an A7750 with decorative plates to make it look like a P.9010. We can hope, but these two are unrelated.
Price and details are missing. And 46 instead 47mm, i guess they will be adding + 1 mm after the release.![]()
I think Puretime is down, any info on this?
Will the blue face fit in the V2 case?
Why would someone do that? The cases are different. Different watches :facepalm:
The reason lies in preference - i.e. why did some whacked out musician paint a glorious Lambo pink??
Marker is whiter now which is closer to gen. Previous version was same color as luminova markers and was wrong. If you Google and see pics of the gen 382 the marker has to be pure white.Can anybody interpret the last comment on the marker? First comment is on the independent hour adjust and the other functions as per gen. The second comment is on the date, where it cannot be adjusted quickly but will move with the time adjust (as far as I can tell). The third comment has me stumped as I'm not sure what's 1:1 about the new markers.
