PAM 111 vs 312 for a first and only Panerai purchase?
CurioLeo
GPsy King
1,248
1,143
Australia
Before you jump in and buy a 111, what is the size of the top of your wrist and is it relatively flat or curved ? I have a 195mm wrist and it is very flat on top . The 111 sits much better than a 1950 case.
Reactions: James2020
Duckber
1,585
869
I got a 6.5 inch flat wrist but can handle a 42mm VSF seamaster... I'm assuming 44mm Panerai models are comparable
CurioLeo
GPsy King
1,248
1,143
Australia
Don't assume, it isn't so much the quoted face diameter as the back profile of a watch that determines how it wears. The 111 is flatter, 1950 is more curved (like most 47mm models) a flat 6.5"" will probably be better suited to the 111
SuperLory
Well-Known Repist
22/10/15
8,505
5,118
1950 case is not the easiest to wear, hope you got the message
Duckber
1,585
869
Yeah I'm going with the 111 for now. I'll have to stop by an AD to try out a 1950s case to see if it's compatible with my wrist
CaptainSplash
1,457
1,624
And then the hunt for a Noob 111 starts.... Good luck, and do let us know which TD has them ;).
Sent from my SM-G988B using Tapatalk
PAKITO
2,164
393
España
I have had both. And both are spectacular. But finally my heart has settled on 312.
The 1950 case has a larger watch look (perhaps because the dial is larger than the 111) and I love that.
Although I have to say that the 111 is also a fantastic choice. A classic. A watch of those "a lifetime".
I do see an indisputable advantage, in my opinion, that 111 has over 312, the movement. It is much easier to find parts or even Swiss movements for a 6497 than for a cloned P9000.
But I agree with the others that you should buy both and try for yourself which of the two satisfies you the most.
2e18281754db63017243332d8ca99202.plist
eb99eff47d8b4d6da71ea091ea965bba.plist
a45d4d8c28dfd5f40b5addbeaf99c993.plist
78e8b17b940881c664ca4df093c35a57.plist
59d930a45ad328bf9b0233c95e3ab7c1.plist
762d26077671efabe552aaa68cd6d7d0.plist
058f1427c7d4290d617adf7f5705e56e.plist
ce9fb80f830c1fde39a0c3007b2ded7c.plist
Here are several pics of two watches.
The lume are very similar in both.
I hope can help you.
Enviado desde mi iPad utilizando Tapatalk
Tobel
5,496
3,731
For me the 312 is just more refined. The case is more elaborate even though it's subtle. You have more harmonious curves in my opinion, less boxy, you have the mix of brush and polished
But too everyone their own
Tobel
5,496
3,731
Ah and metal hands Vs the plastic looking white second hand and the black hour and minute hands.
KOT1917
3,395
5,533
Russian federation
For me the 312 is just more refined. The case is more elaborate even though it's subtle. You have more harmonious curves in my opinion, less boxy, you have the mix of brush and polished, and you have a sandwich dial which I prefer over the sausage dial that I find too basic
I completely agree that everyone has his own, but I want to note that 111 also has a sandwich dial.
Tobel
5,496
3,731
You are right sorry for the mistake, I think I got it confused with the Pam 005. Thanks for the correction
My other arguements stand ;)
Reactions: KOT1917
Duckber
1,585
869
Okay, interesting update...
I went to a Panerai AD today to try out some models.
I tried the replacement of the 111 of which the model's name escapes me, and the 1312, and some 47mm models.
I was very surprised to find that the 111-equivalent, while very nice, did not connect with me. The 1950 case did much much more. Not only that, the 1950 case wrapped around my wrist nicer!
I loved the brush case and polished bezel. I loved the case shape over the standard Luminor. The all polish 111-E did not look as striking.
And an even crazier outcome was that while trying out the 47mm variants, I was able to wear them well. So much so that the AD said he preferred the 47mm on me.
In all honesty, if the rep was still produced I'd go for the 47mm 127 by Noob. Does anyone know why they stopped making it? I thought it was a hit...
I will have to change my order from the 111 to the 312. I don't like the thickness nor the date of the 312 but the pros outweigh the cons... if the 1312 ever gets repped I'll sell the 312 and go for the 1312 instead. They both have cons but the 312 definitely edges it out for me.
KOT1917
3,395
5,533
Russian federation
An unexpected reversal. The PAM1312 was made, as rep as far as I remember, but it will be thinner than the 312.Now it is not produced, but you can find one m2m .
Duckber
1,585
869
I'm just as surprised as you are haha
Do you know which factory used to produce the 1312 you are referring to?
When it comes to m2m I'm definitely keeping my eyes on the 127 as well
KOT1917
3,395
5,533
Russian federation
The PAM1312 was ZF and V6F. The main thing to pay attention to is to have the correct shape of the case, the first versions were with the old 1950 case like the 312.
Reactions: Duckber
Duckber
1,585
869
Thanks for the response.
The 1312 and 127 are huge community favorites. I genuinely have no idea why factories would stop making heavy hitters...
James2020
422
175
Something to consider is whether you are OK with the hand wounding movement of the 111, especially if you plan to wear it on a regular basis. Some people may find it a chore to wind the watch every 1-2 days while some enjoy it
Reactions: EuroTime25
EuroTime25
Lost Soul of Watches
1,084
1,359
West USA
Thats the best part. You are manually giving the watch life. Then you hear its heart ticking.
