- 6/9/22
- 10
- 8
- 3
Wow, thanks for the quick reply what a great ideal that is. I will try that tomorrow. It’s won’t stay popped in. I really appreciate you.Look at the underside of the bezel and locate the hytrel ring (a rubber gasket) if it's not in there, or it's not all stretched and fucked up you can just press it back on
If you press it back on but it easily comes off again get rid of the hytrel ring in there bc it's fucked, and if it's a clean factory watch (judging by the insane amount of grease there it probably is) then follow this link
Hytrel Ring for 116610LN - Dimensions
Hey, Does anyone happen to know the dimensions of a gen hytrel ring for a Date Submariner 116610LN? I know the VSF takes gen and I'm trying to get an aftermarket one, rather than paying £100 for 2 rings. AliExpress sells loads but I'd need to know the diameter, height and perimeter (I...forum.replica-watch.info
As you can see here in KJ2020's post you can replace the gasket with a piece of fishing line usually about .5mm to .7mm, clean factory bezels don't fit aftermarket or gen hytrel rings so this is your best option and it's easy. If you get a line that doesn't fit just take a pass at it with some sandpaper and try till it makes a decent fit and press it back on to the watch
No problemWow, thanks for the quick reply what a great ideal that is. I will try that tomorrow. It’s won’t stay popped in. I really appreciate you.
Ring looks good, almost sounds like when you cut a oring on a carburetor to get it to fit. It doesn’t want to come out easily by using my nails, I’ll work on it tomorrow. Yes it is a cf.No problem
As an alternative you can try to just cut a piece of the existing hytrel ring out if it got stretched use a toothpick or something and resit the modified gasket into its slot and see if that helps
I linked the fishing line thing instead of saying to get an aftermarket ring or something because if it is a CF the aftermarket/gen rolex hytrel gaskets don't seem to fit (assuming it's the same as the CF Pepsi bezel)
Going to take the seal out and try it this week. Need to buy some line so I have it. Glad to hear it works.Follow kj2020s thread to a tee and report back if you have questions.
The fishing line technique works better than rolex's design and is easier to do than you probably think.
It's best to start small and make your way up, if you start off too big, getting the bezel off again will be a nightmare
Went with what Silent said started small, .61/.024 too small which I should have known. Better to be safe than Sorry do not want it to get stuck. .65/.0255 will be next the try .67
Got it. It’s a little tight but for now I’ll leave it be. ThanksTried it, no luck.
