Noob V9 sub bezel replacement
Timeseetime
15
I need to pop off the bezel from my noob V9 black submariner I got from BK a few years back and replace it. Anyone know where I can get a replacement that will match? Thanks in advance
37,209
78,531
Reactions: Timeseetime
Timeseetime
15
Pretty much all Rolex ceramic inserts (gen and aftermarket) for 40mm watches will be the same size. 30.8mm x 38.0mm
You can buy a cheaper one on AliExpress but it will likely have white marker fill (not plat) be thinner and have a crappy pearl. Best bet is buy a CLEAN insert which is great.
If your marker fill is just faded or lost, you can try doing a paint mod.
Insert paint mod - my Molotow cocktail
Insert paint mod - spray paint
Insert paint mod - latest recommendation
Thank you So much… That is very helpful
