Noob V7 nodate Sub bezel stuck?
CycleBuyer
275
32
Hello,
As per title my BK V7 dateless noob has a stuck bezel. I’ve no idea how it happened. I’ve searched the forum and found this recent post
https://r.tapatalk.com/shareLink?sh...mobiquo/redirect.php?tid=7795496&share_type=t
But I did not want to threadjack.
So... how do I fix a stuck bezel? It won’t move at all. And is my bezel like a regmariner bezel or does the V7 use OEM style (in either case, how do I proceed?).
Thank you!
bobandshawn
3,443
327
Florida
If it's from BK then its water resistant. Put it in the sink and soak in hot water for a few minutes. Try to work the bezel free (might need some floss). They can get gunky depending on your use/environment...
CycleBuyer
275
32
Thanks for the responses! I’ll try water and floss first, surgery second! Keep your fingers crossed... thanks again!!!!
CycleBuyer
275
32
Ok so now the bezel is really clean and has great dental hygiene but neither the water nor the floss nor the oil I tried managed to free it.
I suspect if I manage to pop it off I’ll need a spring and a little ball thingie. Does anyone have a favourite source?
