Here are 2 close up photos of the new Submariner bezel click pin design. Vastly different than what it previously was - more closely aligned like the genuine Sub click pin.
My question however is that the pin, when inserted into the hole in the case, if not pre-positioned exactly correct, the tip of the click pin will not engage the teeth of the bezel and when the bezel is snaped on, it will rotate but make no clicking noise at all.
Is there a secret to aligning this click pin wire before snapping the bezel back on?
