New project Super Franken Omega PO Casino Royale "007" 45.5mm. mit 1120 movement und Gen
Mercedes123
665
104
Deutschland
Gen Caseback OME-112ST1703
Presentation,
New project Super Franken Omega Planet Ocean Casino Royale "007" 45.5mm. with 1120 movement and Gen 2500 rotor.
In this project, up to the UPO Rep case, only Gen parts were used all parts listed at the SuperFrank Omega Planet Ocean Casino Royale "007". installed
, it took quite a while until I had ordered all gene parts but now it is time again.
Santre22 has built the 45mm franc Po Casino Royale "007" it was only gene parts used up the UPO case and I am really very satisfied with that Santre22 has again a wonderful
Franken Casino Royale built by him I also have the Gen movement holder and the Gen 2500 rotor which is a super graduation for the project
X21285 Omega 082SU1703 - Planet Ocean Black Bezel Insert
Omega 085ST0090 - Bezel Wire Clickspring
Omega 129ST0515 - Bezel Flat Click Spring
X22746 Glass Gasket (X22746)
X20079 Omega 062SB3063- Sapphire Glass
X20376 Omega OME-2500-Dial # 3 (064WK3170001) - Black Dial
Omega Planet Ocean Casino Royale "007" SPECIAL COMPLETE HANDSET 2907.50
42184ST Omega 069ST42184 - Crown
X12870 Omega 090ST1232 Case Tube
HE Valve. 086ST0115
HE tube. 090ST1242
HE Valve Head. 286ST0005
HE Valve Spring 085ST0067
Gen movement holder 2500
Gen 2500 rotor
Gen Omega Planet Ocean Stainless Steel End Link / 951 + pin & tube
Gen Omega Bracelet
Gen spring bars
Gen Omega Po End Link OME-026ST / 951 Stainless
Rep 45mm UPO Case
santre22 tested waterproof up to
100m positive
santre22 super work as always thank you
for beautiful Franken Omega Po 007.
Mercedes123
665
104
Deutschland
Presentation,
HE Valve. 086ST0115
HE tube. 090ST1242
Gen 2500 rotor
Gen Omega Bracelet
Gen spring bars
Gen Gen Omega Po End Link OME-026ST / 951 Stainlessaseback OME-112ST1703
Rep 45mm UPO Case
d4v3
DO NOT TRADE WITH ME
20/3/13
910
264
Pure lust, great pictures mate thanks for sharing!
miquel
120
Wow - great job on a great watch! Nice work!
Were you able to source the Casino Royale case back as well?
Now you just need to grab your Walther and take out the baddies.
miquel
120
Nice!
I think gen case beats rep CR case back any day...good job on a great watch. Too bad Omega discontinued it.
Mr. Pap
7,350
171
Beautiful project! Nicely done!
Added to the database!
Danza1813
Tempus Fugit
1,749
591
Lovely watch mate.
