Need help - Misaligned ZZF No Date
Mr.Swackhammer
On the hunt
1,231
833
The North, Europe
Hi,
Location, Europe.
I'm in need of a competent repair job for aligne the dial of my watch. See picture.
Either aligne the dial or rehault, but I read that aligning the rehault it quite impossible.
ben_a34
136
181
Dial/movement is probably slightly rotated. Just open case back, loosen the movement holding clamp screws (don't even need to remove) and turn the whole movement a fraction until aligned. 5 minute job. Limiting factor is obviously how much wiggle room there is with the stem.
Sent from my GM1913 using Tapatalk
Mr.Swackhammer
On the hunt
1,231
833
The North, Europe
Thank you for the info, sadly I'm not comfortable doing this myself...
ben_a34
136
181
Try contacting interaktiv - think he is EU based and gets good reviews here.
p0pperini
patr0n h0arder
8,992
30,185
It does look like the dial could do with rotating just a couple of degrees clockwise. It really is a very simple DIY job. But yeah, one of the forum watchsmiths will be able to sort it for you in no time.
Mr.Swackhammer
On the hunt
1,231
833
The North, Europe
Many thanks! I have reached out to Interaktiv. Hopefully he will be able to help!
Don't want to risk ruining anything with me zero experience. I can switch a bracelet to nato only ;)
Reactions: p0pperini
Mr.Swackhammer
On the hunt
1,231
833
The North, Europe
https://clickpix.org/image/20210616-183141.Zch3GR
What can I do from here? Remove the two small screws on each side and it should be able to rotate the whole movement / dial?
ben_a34
136
181
Yes, the two outer screws. Just loosen them a turn. Then see if the movement will rotate half a mm (you won't be able to move it much due to the stem, but there hopefully enough leeway to align the dial). Then just tighten up. Don't force anything as obviously the stem will break or end up bent!
Reactions: Mr.Swackhammer
Mr.Swackhammer
On the hunt
1,231
833
The North, Europe
Many thanks. I'll give it a go.
