Need help - AP 15703 Screw
germanynrw
626
380
Hello everyone,
I need your help once.
The screw turns into empty space and doesn't come out.
What can I do?
Thank you.
  • Sad
Reactions: Oilime
Oilime
Proud daddy
1,827
4,580
something similar happened to me too because I used a crap screwdriver. A watch smith could remove it with a proper one, otherwise he said he would have had to drill it
Martycus
Put Some Respect On My Name
4,457
3,546
I assume this is from a threaded lug bar? if so, as pointed out, use a straightened out paper clip or for something that's more solid or a 2mm drill bit to push it out. try to drip the lug area with wd-40 to lubricate or loosen it
Reactions: Oilime
