I'd like to know what that means as well.
Yes. it is a good watch. The movement is a bit tricky compared to one of the previous 42mm I sold on here however. I think it may just need more wrist time.
Possibly he's talking about the DG highbeat Asian movements food in some v5 PO's. DG's are basically an overclocked a21j - they don't last to long, but are cheap to replace..
VS a reg a21j which is cheap, but doesn't have a smooth sweep.
Or vs an eta which is expensive compared to a reg DG and sweep almost identically (but etas last much longer and work much better)
What are you saying amp? Is that North Bay heat getting to you? :rofl:
Common "luck of the draw" issues seem to be crooked dial markers, primarily 6,9 and 12, the latching ball on the clasp and tube/crown threads. My markers were straight but the clasp spring and tube threads hit me quick. Not a biggie though, to me the watch is definately worth dropping a few extra dollars into.I bought an A-2824 and the V edition with the orange bezel..I will keep this movement and if something goes really wrong i will swap to the Eta..I just asked if anyone has just the same because most people here buy the one with the black bezel..
