Marina Militare 3646 Modded (updated w/ vintageing process)
-falco-
70
Marina Militare 3646 Davidsen with Germano custom-made strap incl. sewn-in buckle
Hope you like it :victory:
Mods done:
Replaced dial with thin lume version
Aged dial/hands, case, crystals and strap using various methods
Aged/darkened Rolex bridges using phosphoric acid & steel wool
EDIT UPDATE:
Vintageing process;
First, most of these instructions I've found on the forums and my sincere thanks to those posted
similar instructions before. Second, try at on risk.
Dial: brushed lightly w/ steel wool and a thick mix of (chewing) tobacco, Nescafe and sugar
mixed in just a little cold water is rubbed on the dial with q-tips.
Careful around dial text since the text is water soluble in luke warm water.
Extra sugar can be added into mix and placed onto dial numbers if you want a more glassy/shiny look
on these.
Hands: Fine sandpaper onto surface, then paint them w/ diluted mix of the dial mixture
Case: Press granite stones onto case, use sandpaper, steel wool and cape cod polish.
Crystal: steel wool around outside edges, diluted yellow ethanol marker pen at inside vertical edges
Strap: steel wool on buckle, soaking strap overnight in leather oils, dry, and wiggle the strap in
all possible directions. Polish leather when dry w/ cloth to get a shine.
Rolex plates:
First note that winding stem of Molijna movement needs to be removed in time-setting position,
but still can be messed up. Movement also prone to rust. Please read Ziggys posts about it.
Also acid is dangerous, wear gloves and goggles.
Remove rolex plates and leave in at least 40% phosphoric acid at least overnight until darkened in right shade.
give it a light polish with steel wool and apply light coat of anti-rust oil like WD40.
Alternative to phosphoric acid is gun bluing but movement will get a blue/black instead of grey/black tint.
Additional mods possible but not tried yet:
Davidsens crown doesn't fit close to the case, tube can be removed & grind down for this and inserted deeper.
Did sort of like it the way it is though.
Lug welding, need to find proper cheap equipment or a good watchsmith.
That's it, don't be afraid to try and if I can do it you can do it
qt11
22
wow, absolutely stunning... where was the dial sourced from ??
-falco-
70
Thanks :D
Dial is a thin lume MM from Davidsen
Vintaged using steel wool and applying tobacco, coffee w/ sugar solutions etc.
qt11
22
thanks falco, great watch
i've just email david to see if he can do another....
how did it come from david, was he able to fit the new dial or was that something you had to do ?
i've got a few old molnija movements that i'd like to use in a similar watch...
you've inspired me !!
horologie_unitas
5,148
very nice...seems like a lot of work....very very vintage and unique....goes good with the 08 !!
Niko
910
Outstanding!
You should be very proud of that project.
azgjav
1,063
c'mon..where did u get this gen vintage panerai??
:D great job on the mods!!
-falco-
70
Thanks!
I'll post full description of vintage process later today, since I'm curently at work.
The Luger P08 is a genuine ww2 german officer issue that I've just finished restoring but tried to keep its agened patina and wear.
aronax
30/9/06
11
Stunning !!!
very nice !!!
thanx for sharing
cheers,
Aronax
moggio
2,788
damnn dude....this is gen..not reps..LOL :) ...thanks for the photos :) :shock:
ssalxpanerai
556
-falco- said:
Thanks!
Thank you so much falco for your sharing. It really inspires me a lot. Great job!!
-falco-
70
About lume, gen should have almost none or no lume, depending on if relumed at any stage.
you can control this by adding more of the "madasboot" mix (sugar coffee ..) to dial and hands.
Hands lume seem to dissolve in the mix, Davidsen dial absorbs A LOT of the mixture over time (1-2 weeks)
, so you might need to re-aply. The more mix you cover it with, less lume.
VDBroucke
145
good work
i love vintage pam and i work same and another pams
in the future i work buckles and straps for pam vintage and modern
crazy straps ,big buckles,future straps,carbon-buckles...
