Hi all,
I recently receive the IWC Top Gun Ref No. IW3890-01 by ZF, which I ordered from PureTime (great service by the way! Kudos to PT!)
This model is basically the Top Gun model first released by IWC in 2016, featuring 2 subdials on the 12th o'clock, with the outer for minutes and inner for a 12-hour stopwatch dial.
As you can see from the Imgur link. it came nicely packed in a long ziplock bag by ZF was nicely protected from scratches with protective films pasted all over the watch itself which I removed prior to taking the photos.
Dimension wise, everything is accurate to the gen. Chrono function works great with good depress feel and reset function works brilliantly with flyback action. The double subdial on the 12 o'clock works (both the minute hand and the 12-hour counter dial hand), contrary to what others believed
The Calfskin strap is 90% close to gen in terms of detail, quality and feel, with the rep feeling a bit stiffer (which I am ok with, understanding that we have to give-and-take at some point when dealing with reps).
The clasp works perfectly very close to the gen, with a secure, firm and load clip sound when wearing the watch and closing the buckle to secure the watch onto the wrist.
The lume is bright and clear, evenly applied across the markers with lume. Indices and numbers are accurately applied in great details.
Sapphire glass is beautifully done with blue hue under light.
Winding is firm and smooth. Screwdown crown function with no issue at all.
The only downside for me is the difference in the 12 O'clock double sub dial, in which the gen has the inner dial countersunked while the reps have in pop-out slightly. But considering the fact that ZF able to modify the A7750 to have double sub dial working, I personally can overlook that part.
All in all, the watch feels very solid and well built! Well-done ZF!
Highly recommended to any IWC Top Gun lovers!
Images are in the link here: https://imgur.com/a/FIbOXA3
Cheers to all! Thank you for taking the time to read my post!
