Hytrel Ring for 116610LN - Dimensions
pane123
34
Hey,
Does anyone happen to know the dimensions of a gen hytrel ring for a Date Submariner 116610LN?
I know the VSF takes gen and I'm trying to get an aftermarket one, rather than paying £100 for 2 rings.
AliExpress sells loads but I'd need to know the diameter, height and perimeter (I think).
If anyone has an AliExpress link to what I need I will love you forever. There are a couple at $20 but that's a bit expensive without being 100% certain it will fit.
Thanks in advance.
Reactions: keisuke_z
pane123
34
subscribed
I contacted the seller and these should be available tomorrow at $12:
US $18.60 | Gasket For Rolex Submariner GMT Bezel Waterproof O Ring Rubber, Watch Parts
https://a.aliexpress.com/_mO27Xk3
I've also ordered these, so I'll let you know if they work:
Let's shop together on AliExpress with new user coupons
Your US $5.00 in coupons are here!
https://a.aliexpress.com/_mq0DWLV
I can't get rid of that promo link but hopefully it takes you to the product. If not, let me know.
37,541
80,224
I've used fishline as a replacement part several times. Its OK for there to be a break in the perimeter. It's a trial and error thing to find the correct diameter - between .50mm and .65mm is a good place to start.
37,541
80,224
"It's OK for there to be a break in the perimeter"
You can also cut away part of an actual hytrel ring if it's crushed or mangled.
up2wind
335
80
What a genius, fucking fishing line!
Never thought of that. Will try it out. Thanks a lot
37,541
80,224
If trying fishline, start with a small diameter line and work up incrementally til an acceptable fit and function are achieved. It's possible to press a bezel with fishline in it that is too big in diameter to allow for bezel rotation. If that happens the bezel can be very difficult to remove (sometimes not possible). There is a workaround if this should happen but the repair will go much more smoothly if you don't get into this situation.
hm11esh
422
105
pane123
34
https://forum.replica-watch.info/fo...as/10064127-clean-factory-zzf-v4-clicks/page3
I also need this ring for 126610 vsf. I thought I found a solution, see the link. But the guy who makes these rings hasn't been in touch for 9 days after I transferred him $60. I'm looking for alternative options. I will follow this post, please let me know if you find a solution.
I've got 5 gen spec rings arriving but they will take a while to arrive because I'm in the UK. Gen is supposed to fit VSF. Mine is 116610LN so if it fits that it should fit yours.
I'll let you know if it works:
https://www.ebay.co.uk/itm/5-WATCH-...2349624.m46890.l49286&mkrid=711-127632-2357-0
keisuke_z
511
311
Apologies for bringing this old thread back up - I’ve got a VSF 116610 whose bezel is not playing nice. After some investigation I found that the lip on the retaining ring is pretty high compared to a Clean retaining ring, and from the other threads I’ve read, it looks like the VSF doesn’t take a gen/aftermarket replacement hytrel ring? In which case, if I need to replace the current ring, which appears a little mangled, then the fishing line is the best option available?
Reactions: Liam F
derjenigewelcher
Watch enthusiast
9,957
13,708
Switzerland
https://de.aliexpress.com/item/1005...1;17.56;-1;-1@salePrice;CHF;search-mainSearch
pane123
34
You can get 5 on ebay for not very much. It was unbelievable how easily it went in and it's holding strong:
tps://www.ebay.co.uk/itm/5-WATCH-BEZEL-GASKET-FIT-BETWEEN-CASE-FOR-ROLEX-SUBMARINER-CERAMIC-116613-116610-/161620824457?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0
